I know my questions have probably been answered many times,but....I am on a VERY slow dial-up system ....and have limited electricity so I need to be specific to narrow down the info. I apologize in advance.
To keep it simple...I want to build a simple set of full range speakers. They will be for a 12' x 12' room with 8' ceiling. I like all kinds of music,jazz and blues are my favorite. I am a carpenter/woodworker,so the cabinets are my forte. My main question is...what drivers would you pick? I live in the USA,so thinking Fostex is the choice? I pretty much know nothing on the speaker part. I have read many threads but they confuse the heck out of me. So i guess these are my questions. #1 What driver? #2 What size cabinet #3 Do full range drivers need special wireing(caps,resistors,etc)...or just a simple direct connect ? Sorry for the dumb questions,but i have to start somewhere. Thanks. |
#2 | |
FE127, FE126e, FE167, FE166 would be a short list of Fostex. eN versions for a step up. Once you choose a driver pick an enclosure (althou the available enclosures available may hekp you choose the driver) Personally i try to avoid filters, but sometime people find BSC or other FR teaking networks useful. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Thanks for the info Dave.
When you say filters...what is that? BSC or FR ? Like I said I know VERY little abut full range speakers. Maybe filter is a cap or resistor ? I can build any enclosure to suit my room,just wondering what driver and what size enclosure to go with. Also what style enclosure. thanks |
#4 |
BSC = Baffle Step Compensation
Baffle Diffraction Step FR = Frequency Response A few examples of filters are to notch out peaks (they reduce the peak's visibility in a FR chart, but the resonance that causes the peak is still there, so sometimes the cure is worse than the problem, my approach is to try to reduce/kill these at the sotce by modifying the driver), broadly reduce the midrange so that it is closer in level to a falling top & bottom (using a high output impedance amplifier can have much the same effect), or flatten out a rising top end. dave
#5 |
there are other nice full rangers as well, don't limit yourself to Fostex... CSS, Markaudio, Tangband, ....
1 question that is important to make a choice is if you will have a fixed listening position or not? if you have, then a large driver will be OK, if not you'll might want to go for a smaller driver. |
#6 |
Hi Karlton,
Lots of cool designs here: The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs Sounds like you have cornes as a possibility: Bigger Is Better 'BIB' Cabinet Dimensions - ZillaSpeak (click on "How to Build a BiB" and on the brands of drivers to see specifics). If you crave an understanding of the principles, read these: Quarter Wavelength Loudspeaker Projects Edit: dang, why does it convert URL's into page titles?
#7 |
Thanks for the links and info. Looks like I have alot of reading to do. I really want to do this,but want a full understanding before I even start.
#8 | |
And if you can't go listen to any of the drivers before you build, then all you can do is read plenty and take your best guess. For your size room, I can say that I would be looking at something like a Fonken or a Metronome with a Fostex FE127e. You can find threads here about those designs. BTW, no driver is perfect; no design is perfect. It all comes down to what compromises are acceptable to you--and only your ears can tell you that. Good luck, Jim
A day without music is like a day without food. |
#9 | |
#10 | |
If you look at the curves of the baffle step phenomena, the ripples seen in less ideal enclosures is baffle diffraction. dave
| questions about attempting full range surrounds. | paul3221 | Full Range | 22 | 22nd August 2009 03:54 AM |
| Frequency range of the human voice & full range center channel speakers | jwmbro | Multi-Way | 31 | 20th January 2008 04:07 PM |
| full range speaker, bunch of questions | Shpoop | Full Range | 6 | 23rd July 2004 01:05 PM |
| Full-range driver general questions | Bill F. | Full Range | 8 | 4th March 2002 02:24 PM |
| Page generated in 0.13259 seconds (82.51% PHP - 17.49% MySQL) with 10 queries |
