Old 27th October 2009, 04:15 AM   #1
Default My FR OB idea
I do not know if someone has put this together before but. I figure I could have a crack at it. I am thinking of a OB FR set up consisting of.....
1 or 2 (don't know if 2 is overkill) 3" FR woofers on top
1 8" High Q woofer on bottom.
My thoughts on dimentions are....
Front baffle....24L by 18w
Side open walls 24l by 10w
Bottom support 10l by 18w
I would be putting some sort of dampening inside of the cabs.
I want to keep this on the super cheap. The 3" woofers are $11 each, and I would perfer not spending more then 25-50 per 8".
Anyone got any ideas on a decent sounding High Q 8" woofer for the price I am stuck on??
Old 27th October 2009, 08:48 PM   #2
chris661's Avatar
The idea you're thinking of is FAST (Full Range And Subwoofer Technology), and is a good idea, as you take the crossover away from the sensitive 3kHz band which is where conventional 2-way speakers have their XO.
What FR drivers are you looking at?
Chris
PS - you (could) be looking at a Pro woofer for higher Q at 8" - something like the Eminence Beta 8 (tested on various OBs with some good results)
Good luck with the project!
iPod Touch (playing LossLess) > 4th order LR crossover @80Hz > Amp-6b > Fostex FE126eN in folded ML-Voigt Pipes
------------------------------------------------------------> Samson Servo 240 > W6-1139SG Tapped Horns
Old 27th October 2009, 11:34 PM   #3
Not really sure. I think now I might be able to put a bit more quality into the factor as my budget got a little larger. I don't think I will be running a panel amp or a sub amp to the 8".
I was thinking something like the Audio Nirvana Super 8 but the Q is quite low.
What could I get with $300 driver budget thats good OB?
I think I want one 4" and one 8" per OB.
Thanks!
Old 27th October 2009, 11:43 PM   #4
Parts-Express.com: JAMO 20418 8" Treated Paper Cone Woofer | JAMO 20418 8" Treated Paper Cone driver Woofer speaker midrange mid
This looks like a steal to me no?
I am guessing a t-amp or my 25wpc pioneer would have a issue driving this?
Old 27th October 2009, 11:46 PM   #5
Godzilla's Avatar
I bought a pair the other day... planned on stuffing it into a sealed box plus
Parts-Express.com:*3" x 7" Wide Dispersion Piezo Horn Tweeter | 3" x 7" tweeter Wide Dispersion tweeter piezo horn driver piezo driver ksn1025 PiezoHorn050109 PiezoTweete070109 npa00454 TweetersTerminalsHorns090109
Cheap fun... when you buy these PE buyouts you don't have the luxury of any charts and have to go by the specs and hope for the best.
Godzilla
Old 27th October 2009, 11:49 PM   #6
DougL is offline DougL  United States
My experience is a single 8" woofer is not going to be useful for OB.
You would be much better served with a high Q 12" or 15" driver.
I user a couple of 12" no name buyout drivers and a NSB 4" with great results.
There is a great design floating on the board using the Eminence Alpha 15 and a full range driver.
New MJK Baffle Article
I would not use two 3" unless you are going to use a tweeter, because of lobing.
You're idea is good.
Good luck.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 28th October 2009, 12:00 AM   #7
Looking at current buyouts at PE:
Parts-Express.com:*JAMO 20392 15" Paper Cone Woofer | JAMO 20392 15" Woofer Treated Paper Cone driver speaker bass
Qts is low(bad), so is Fs(good), Xmax at 4mm (probably OK if eq isn't too heavy handed)
Doug
Old 28th October 2009, 12:01 AM   #8
preiter is offline preiter  United States
preiter's Avatar
Hawthorne Silver Iris is $300 a pair and made for OB.
Drivers
Old 28th October 2009, 12:28 AM   #9
huh. Well thats no good, the Q on the 8 was .7 i belive. I am not a big bass head so if this is a bass extention issue I could live! At $10 a pop honestly could you complain?
Is there a fostex driver thats good for OB?
Since I am planning on using a larger woofer with higher Q, does the smaller woofer need to adhere to this?
Old 28th October 2009, 01:59 AM   #10
The jamo 6.5 is Q 1.28. Would that at least extend omph with the regular driver. And since they will be ran together, will this fix the somewhat low SPL? I figure it couldnt be that bad.
A Audio nirvana 6.5 and the jamo 6.5? That would be quite cheap to put together. A good first take no??
Different pre amp idea bartek Solid State 3 25th March 2008 04:42 PM
I really have no idea what I'm doing here... d to the g Multi-Way 10 7th March 2008 07:04 PM
P.S idea noyan Power Supplies 15 19th December 2007 09:50 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 09:18 AM
Just an idea bob123 Subwoofers 4 9th April 2006 03:28 PM
Page generated in 0.10658 seconds (82.87% PHP - 17.13% MySQL) with 11 queries
