Old 28th October 2009, 04:14 AM   #11
DougL is offline DougL  United States
At $10 a pop honestly could you complain?
It will sound fine. The issue is that the baffle roll-off is 6 db per octave starting at Fequal. If your baffle Fequal is 120 Hz, (just a WAG) you either are 6 db down, need twice the Xmax, or twice the area at 60 Hz. There are spreadsheets that calculate max spl. Run the numbers, but my intuition is that a 40 Hz base note could bottom the woofers at any reasonable volume. I had to keep the crossover point up (above 200 Hz) to avoid bottoming the mid-range.
If you try it, let us know. As you say, the price is right.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 28th October 2009, 04:21 AM   #12
I shall. There will be pictures and all!
I want to sand and gloss black/red what ever gets built. So it will be while before they are done.
I think I am going to buy a pair of the little $10 3" and build a little MDF home for them to tinker around with in the bedroom to see how interesting the full range thing can be before I spend over $100 dolla!
Does anyone know how much mdf for my size will be.
I would say 30f by 20w FB / Small same height arms?
Old 28th October 2009, 06:10 PM   #13
chrisb is offline chrisb  Canada
Originally Posted by Ppasco1018 View Post
snip...
Is there a fostex driver thats good for OB?
Well, if you read the MJK project paper referenced earlier, you'll see he nominates a range of Fostex drivers for the mid/tweeter portion of his 2-way OB.
There are more than a few builders who've been very happy with the results. Probably most effusively - Jim Shearer and his FF85K - see his posts starting about here:
New MJK Baffle Article
Mind you, any of the suitable Fostex drivers will cost more than $10 each
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 28th October 2009, 06:23 PM   #14
Godzilla's Avatar
Today i received the 5.5" jamo and the 8" jamo from PE... They look great in the pictures but not so great in person... plasticy and lightweight. Every single Fostex i have seen simply looks and feels better made. Every single TB i've seen looks and feels better made... I remember getting the titanium 3" TBs and couldn't wait to hook them up. Just looking at these jamo's i don't even want to hook them up. They look like they will break if i turn up the volume. Uhg... oh well, they only cost a few bucks.
Godzilla
Old 29th October 2009, 05:47 AM   #15
I figure it would be a start though. I bought a pair of those insignia ns-b2111's today just to tide me over until I had the time to start building my OB's. Dear lord they sound fantastic at low levels (cost wise-paid $60) but once you crank up the levels the thin box really shows. I think I am going to do the rock hard mod to them and shove a 6.5 full range in them until I get the time to build the OB's. I think I am stuck on a 6.5 and a 8 or 10" for the OB.
I did a paint draw up of what I sort of want them to look like in the end.
Tell me what ya think!
Old 29th October 2009, 05:49 PM   #16
Ppasco1018, I think that you hear woofers' resonance, not the box.
stock crossover does nothing to attenuate that resonance.
here is proper crossover design for these speakers:
MurphyBlaster Productions
Old 29th October 2009, 09:53 PM   #17
Cool. This box is real flimsy. Its only 5 dollars to add the rock hard and maybe two days of my time. I have the slightest clue how to do crossover stuff.
Is this a simple upgrade? Thanks for the tip, I can def afford $40 to make a better speaker. As when the OB's are done, the FR will be removed from this box and will need to be put back together with the original driver.
Does anyone know what kind of crossover I would have to widdle to use those drivers in my car until I put them back in later on? I would figure it would be a small filter??
Thanks guys, your nothing but help!
Different pre amp idea bartek Solid State 3 25th March 2008 03:42 PM
I really have no idea what I'm doing here... d to the g Multi-Way 10 7th March 2008 06:04 PM
P.S idea noyan Power Supplies 15 19th December 2007 08:50 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
Just an idea bob123 Subwoofers 4 9th April 2006 02:28 PM
Page generated in 0.09740 seconds (77.05% PHP - 22.95% MySQL) with 11 queries
