Transmission line cross-sectional area question
Old 25th October 2009, 09:26 PM   #1
h@kan is offline h@kan  Sweden
h@kan's Avatar
Default Transmission line cross-sectional area question
I'm planning to build a Classic TL out of standard sewer pipes.
The sketch shows how I intend to construct it.
My question is if this is possible considering the physics of a TL, I mean the cross-sectional area of, especially, section 2 is quite funny. Will MJK's mathcad sheets give me a relevant simulation?
Something tells me that a cross-sectional area like this will be problematic but
thats just a feeling...
Regards H@kan
Old 25th October 2009, 09:48 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
There should be no reason that can't be modeled. With a driver suitable sized for that pipe, it is going to be too long i'd guess.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th October 2009, 10:50 PM   #3
h@kan's Avatar
The sketch is just for illustrating purpose. I think I will use a ~3" FR driver, perhaps Alpair 6, and tune the line to ~65-70 Hz so the total hight of the cabinet will end up around half a meter.
Yes I can model it with MJK's sheets but I was uncertain if the geometry of the cross-sectional area is restricted to certain conventional geometries.
Suppose that you have a A*B cross-sectional area. Wouldn't there be a break-point, when one of the sides become significant greater than the other, when the model no longer gives you a relevant output?
In my case (in section 2) the "A*B" ratio is ~1:12
Regards H@kan
Old 25th October 2009, 11:02 PM   #4
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Give it a relevant input! I would start with a speaker of 100 cm2.
Also , an oven might be useful when playing with PVC...I mean if you don't want to add the extra baffle!
Old 26th October 2009, 08:34 AM   #5
chris661 is offline chris661  United Kingdom
chris661's Avatar
Brilliant idea.
It would be pretty neat to build it out of clear plastic, so everyone can see the "magic" that goes on inside.
Chris
My work: www.grimshawaudio.com
Old 26th October 2009, 10:19 AM   #6
frugal-phile(tm)
planet10's Avatar
The necessary damping would quickly ruin any see-thruness.
Old 26th October 2009, 10:44 AM   #7
h@kan's Avatar
Originally Posted by chris661 View Post
Brilliant idea.
Chris
Yea that would have been nice but besides that you probably would just see damping material, as Dave pointed out, the main idea was to use standard sewer pipes and I have never seen any transparent ones. I can see why considering the conventional usage of sewer pipes
One can of course, if using clear plastic, use some "fancy" damping material
Regards H@kan
Old 26th October 2009, 11:03 AM   #8
frugal-phile(tm)
planet10's Avatar
Organizing the tubes like this is easier to build small cylindersealed at the top. big one on the bottom. Not to scale.
dave
Old 26th October 2009, 11:18 AM   #9
Those fuzzy legs made you brilliant!
<good one , Dave>
Old 26th October 2009, 11:24 AM   #10
Geek is offline Geek
Geek's Avatar
Hey Dave,
Wasn't there a dead hot water tank around your place we could get creative with?
Cheers!
Transmission line cross-sectional area questionHide this!Advertise here!
Transmission Line Question jamiematrix Multi-Way 51 9th March 2013 11:34 AM
Transmission Line Question (Yet Another) schmeet Subwoofers 24 6th August 2008 10:18 PM
yet another transmission line question CharlieM Multi-Way 3 6th July 2008 05:44 PM
another transmission line question CharlieM Multi-Way 8 21st March 2008 11:17 PM
Transmission line question(s) Kris0603 Multi-Way 20 28th September 2005 11:15 AM
