Old 26th October 2009, 10:39 AM   #11
picowallspeaker's Avatar
Those are big pipes , more than a half inch thick , used by public administration for water distribution , I guess . Using orange and gray ones ,which are thinner , brings the problem of bracing , which can be done with lead sheets , and the resulting weight would be then comparable if done with MDF .
Old 26th October 2009, 11:18 AM   #12
h@kan is offline h@kan  Sweden
h@kan's Avatar
Originally Posted by planet10 View Post
Organizing the tubes like this is easier to build small cylindersealed at the top. big one on the bottom. Not to scale.
dave
Interesting! This would be far easier than my original concept.
I can see one problem thou, my kids will probably "fill her up" with lego bricks and other junk
The pipes I'm planning to use are, as you correctly assumes, thin pipes with a thickness of around 5 mm. I think at least the bigger surrounding tube will need some bracing.
This product is cheap, easy to mount and I think it will do the job http://translate.google.com/translat...istory_state0=
Transmission Line Question (Yet Another) schmeet Subwoofers 24 6th August 2008 09:18 PM
yet another transmission line question CharlieM Multi-Way 3 6th July 2008 04:44 PM
another transmission line question CharlieM Multi-Way 8 21st March 2008 10:17 PM
Transmission Line Question jamiematrix Multi-Way 40 19th March 2008 12:21 AM
Transmission line question(s) yacuza Multi-Way 20 28th September 2005 10:15 AM
Page generated in 0.06459 seconds (68.66% PHP - 31.34% MySQL) with 11 queries
