Hi everyone I am new to the forum and am glad to be here!
Me and a good friend of mine are throwing around building a set of full-range speakers. I am a little lost on how I should go about this. I have been reading up and down that a 12v battery powered t-amp and a set of full-range speakers will blow away most speakers/systems in a sub thousands range. Now is this true? I sure don't know. I want to know the advantage and disadvantage of small to larger size drivers. What models of what brands to look into. I plan to use in a ported bookshelf type enclosure. Whats a good t-amp to use? I would like to not spend more then $200pr for the drivers. Sorry for all the noob questions! |
#2 |
**EDIT** Also interested in open enclosure. That seems like it could be rather interesting, and easy to build.
#3 |
Howdy. This weekend, I'm building these which can be built for under $200: http://www.wildburroaudio.com/projects.php
I went to the Rocky Mountain Audio Fest and heard speakers in the $1k, $2k, $20k and even $100k range. I wasn't all that impressed with the big-buck systems. To my ears, acoustic and jazz sound fantastic on a decent fullrange system. I'm not sure they would be my first choice for the style of music mentioned in your sig unless you also mix in a woofer (or at least a sub). For T-amps, I got the Super T-amp at Parts Express. I am happier with a little tube amp, but the Super T-amp has a lot of fans. |
#4 |
HI PASCO,
I too love OB fullranges, they are best sound than a Magnepan 1.6QR, but may be more expensive too. Unhappily OB requires a BIG cone, the bigger the better, under 12inches the bass is too small due front/back self cancelation of the OB panel. Today 2009 there is only one big cone Iam aware, the Nirvana Super15CF(398 US dollars per pair) at http://www.commonsenseaudio.com/an15cfspecs.jpg and seems it is very good sound by the price. But if you want stay away of OB panels, there is a lot of FR options for BR and sealed boxes. My personal preference is the MarkAudio Alpair10(6 inches, 135 dollars each) this Alpair10 is a beautiful driver, a real Hi-End FR, stellar sound quality in a suited BR box(13 liters) and they are hand made in HongKong, the build quality is first class, no cheap parts!! http://www.markaudio.com/alpair/10/fullrange If you have some money to spend, maybe you could want the sweet sound of a Alnico magnet(Alnico is the best sound magnet for any speaker, but is expensive) and try the Fostex F200A(8inches) around 380 dollars at http://www.madisound.com/catalog/pro...roducts_id=265 OOPS the price rise to 440 dollars!!!, since the last time I see this beauty... Please Note: A FR is expensive to made and design, a low price FR always is a bad sound FR. Good Luck!!
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average. Last edited by FullRangeMan; 25th October 2009 at 04:43 PM. |
#5 |
Welcome.
For your first foray into full range or wide band speakers I'd recommend the Pioneer 8", Parts-Express.com:*Pioneer B20FU20-51FW 8" Full Range Driver | woofer 10" woofer full range speaker pa woofer pioneer , paired with a PE Neo Tweeter Parts-Express.com:*Dayton ND16FA-6 5/8" Neodymium Dome Tweeter | tweeter nd16fa-6 soft dome tweeter dome tweeter neodynium dayton audio dayton loudspeaker dayton. Current pricing puts you at @$80 for all drivers. This combo is fairly well documented on this forum and is a great "gateway" set up. Mine are in 2cuft sealed enclosures and powered by a Sonic Impact Gen 1 T-amp. I know, not quite bookshelf enclosures. What I'm driving at is that these are easy to listen to drivers that, in an enclosure this size, might leave you 'wanting' a subwoofer but definately not 'needing' one. R/ Jim |
#6 |
Drivers
While not single driver full range, Hawthorne Audio offers their 15" coaxial Silver Iris for $145/ea. They'll get u started, and if you're missing some bass u can always add the 15" OB bass augmenter. You won't find better OB for less effort and $$$. |
#7 |
I was thinking about the audio nirvana drivers. They seem cheap and well made. As I said before, I cant spend more then $200 for the pair, not $200 per driver.
I was also thinking the Aurasound NS3-194-4B at madisound for $11 each. I figure I would keep my costs down low to even see if I find them interesting before throwing away! |
#8 | |
Those look freaking awsome! Thats what I was thinking about doing pretty much. I was thinking the audio nirvana super 8's for something like that! I have a nice 25wpc int. amp that I have laying around that I do belive is just perfect for a 8". Would It be overkill in a apartment? I have a 600sf place. Am not quite sure what size my living room is. I know it's quite small. |
#9 | |
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 | ||
But be careful -- the Betsy driver is _especially_ for OB, and the Audio Nirvana drivers would almost certainly need a woofer to make enough bass. Some people feel that the woofer is always necessary, but I'm finding I can get by with the Besty. It also depends on the music. If you intend on using just one fullrange -- no woofer -- try to get a driver with a Qts of around .7 or even higher. That rules out using an Audio Nirvana by itself, I think. If the driver has a Q much lower than that, a woofer seems necessary. If you're feeling up to it, simulate first in MJK or the EDGE. Overkill for small spaces? I don't think so, if you really love listening to music (and I'm sure you do). They fold up nicely. I'm starting a thread for these later today ("Dark Stars"). But be warned -- these produce bass of a nice quality, but a limited quantity. Quote:
| Fostexs smaller fullrange drivers questions? | phil09 | Full Range | 9 | 25th April 2008 10:14 PM |
| mostly fullrange | tomtt | Full Range | 1 | 25th April 2006 01:04 PM |
| RCF fullrange | Ahmad_tbp | Full Range | 0 | 21st May 2005 06:13 PM |
| Fullrange Without BCS | johnb | Full Range | 3 | 12th February 2005 10:57 AM |
| Page generated in 0.13083 seconds (83.94% PHP - 16.06% MySQL) with 10 queries |
