Polk Audio Monitor 30 Bookshelf Speaker System (Priced per pair) in Bookshelf Speakers at JR.com
i plan to buy these , as they are very reasonably priced compared to them in bombay, i would like to know are they good enough for a small room and a DIY Chip amp based on TDA7294 thanks |
#2 |
I would think they would be OK for a small room. With a sensitivity of 89dB, the recommendation of 20 watts minimum is reasonable for moderate listening levels. But if you try to seriously rock out, a small amp will quickly reach its clipping point & blow the speakers.
And while I would normally recommend building speakers yourself, I doubt you could build anything at that sale price that would sound better. Cheers, Jim
A day without music is like a day without food. |
#3 |
That's a two way design, not a full ranger. Unless the tweeter is just a plastic decoy, and the 5.25" driver does everything. From the photo, the tweeter looks a little fake to me.
#4 |
The tweeter is no fake. Polk makes good mass market speakers at reasonable prices. The Monitor 30 is one of their lower end products, but still represents a good bang for the $$. And if he had a $200 budget, I could recommend a build that would blow away the Monitor 30--but that's twice what he wants to spend. And then there's the question as to whether or not he wants to do a speaker build (or has the capability to do so.)
Cheers, Jim
#5 | |
only option would be to buy some car speaker of good quailty, i can build a amp but speakers is tooooo diffiuclt for me. and carpentry work is next to impossible . so could you help decide how to go about it , i have 60Watt chip amp, |
#6 | |
#7 |
I think for your room and requirements, you will probably be happy with the Polk speakers.
But if you ever decided to build, you might consider a full range, single driver. Check out some of these designs: planet_10 hifi Cheers, Jim
#8 |
The Cambridge Audio S30 is a better buy, costs 8.5K ex-Mumbai, I guess. You'll outgrow the Polks very soon, and the S30 is pretty much the best bang for the buck under 10K you'll get from branded hifi.
#9 | |
#10 |
Drivers for mFonken or uFonken will need to be had from Madisound or from me for treated drivers.
MDF has been used in the past, a thicker panel material will be required to get teh same stiffness. A good multi-ply is better by at least a little bit. Our favorite sonics wise is bamboo plywood, but it makes for a harder & more expensive build. Of notre is that uFonken flat-paks are available and the same for 4 different milli-sized boxes including mFonken shouldn't be far behind. We think of this as a way to get people just the amount of BB that they need for these small projects (a single sheet is good for 4 sets of uFonken) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Polk Audio MW8000 drivers pair | Rockmore | Swap Meet | 2 | 24th September 2009 05:48 PM |
| Polk Audio db1240 DVC for Home Sub | neeraj | Subwoofers | 4 | 17th June 2009 09:49 PM |
| Measurements of polk audio speakers | Ron E | Multi-Way | 0 | 25th February 2007 01:33 AM |
| Polk Audio Sub? | samsagaz | Subwoofers | 4 | 22nd January 2007 03:51 PM |
| Polk audio 10A crossover problem | argonrepublic | Multi-Way | 2 | 8th May 2005 06:41 PM |
| Page generated in 0.12659 seconds (80.38% PHP - 19.62% MySQL) with 10 queries |
