Originally Posted by planet10
Drivers for mFonken or uFonken will need to be had from Madisound or from me for treated drivers.
MDF has been used in the past, a thicker panel material will be required to get teh same stiffness. A good multi-ply is better by at least a little bit. Our favorite sonics wise is bamboo plywood, but it makes for a harder & more expensive build. Of notre is that uFonken flat-paks are available and the same for 4 different milli-sized boxes including mFonken shouldn't be far behind. We think of this as a way to get people just the amount of BB that they need for these small projects (a single sheet is good for 4 sets of uFonken)
hey guys i m goign to buy the following
Parts-Express.com: Peerless vline BC14WG79-08 5-1/4" Woofer | Peerless vifa BC14WG79-08 5" Woofer bass mid midbass mtm poly cone 2-way Tymphany vline
Parts-Express.com: Vifa D19TD-05 3/4" Poly Dome Tweeter | voice coil vifa tweeters vifa tweeter tweeters tweeter power dome tweeter coils COIL
thye fit in my budget preetyyy well.. now need help the box, can i use winisdbeta for size.. or not. else what cn i use, i m complete novice at speakers.
