I've been pondering whether the folding scheme on the TQWT's (is that lingo going to catch on, or will everyone keep using TL?) I'm building will reduce the reflections that get back to the driver. These guys claim to have it figured out, and they've made some darn pretty bends. I do get the "human form" look. It also sounds as if they are using BSC, which isn't always the case with commercial single driver offerings. Do you suppose those are layered? Seems like it would be tough to make those tight radius bends.
Paul Wild Burro Audio Labs - DIY Full Range Speakers edit: forgot the link on the first go! |
#2 |
#3 |
I meant if one were trying to bend a flat sheet around that radius. I certainly understand that you could layer such a shape.
Paul Wild Burro Audio Labs - DIY Full Range Speakers |
#4 |
I think it would depend on the material thickness and the initial bend radius. You'd have to start with thin material to get the desired shape, and then build up several layers. I'm sure I've seen this approach somewhere.
![]() Jeff |
#5 |
#6 |
Do they want to avoid " interchannel crosstalk" between sections of the pipe?
Seen that way , every section seems free to resonate (or do not!) ,letting acoustic energy "migrate" freely to the mouth. As I see , those are multiple layer CNCed, not curved sheets. |
#7 |
Kerfing would allow those bends easily.
There is also a type of plywood which I know as "Bendy" plywood which is extremely flexible although I would probably just cut the kerfs. CNC machines (routers really) can cut just about any shape and size, wastes a lot of material though and like a lot of "progress" nowadays, the art, technique and craftsmanship is lost .
None of us are leaving this world alive. Enjoy it responsibly as you may. |
#8 | |
frugal-phile(tm)
I think we will continue to see TL used for boxes with openEnd xSection =< closedEnd with the strictest definition being that it is damped to almost aperiodic, TQWT for boxes with openEnd xSection > closedEnd with a linear taper (ie TQWT=TQWP=Voigt). In its broadest sense this is also a horn but a horn is usually openEnd xSection > closedEnd with an expansion which cannot be defined with a straight line. The commercial thing you pointed to is a TL. I would never call that a TQWT. On top of that you can mass load them, and or add an air-cavity. The traditional Bailey/Radford/IMF TL has both, is end loaded, and is not stuffed enuff to fit the strictest definition of a TL. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
I have been following the logic that a recall GM proposing: that there is no electrical analogy to a tapered line, and since TL is a borrowed word, it makes sense to use TQWT for any line that is tapered (in either direction). I could be mistaken, or misrepresenting his idea, but it makes sense to me. I do suspect the term Transmission Line is here to stay. Seems I recently saw some manufacturer referring to it as a "reverse horn." That was a new one on me.
#10 |
frugal-phile(tm)
That is what i meant in the broadest sense.
GM started using the term reverse taper TQWT... i' personally going to stick with the traditional use of the terms -- i have avoided the use of TQWT for sometime, prefering Voigt Pipe. dave
| Buying Jordans in the UK? | johnthedoctor | Full Range | 15 | 29th March 2009 07:20 PM |
| two pairs or jordans for me and my dad? | uzziah | Full Range | 14 | 9th November 2006 03:31 AM |
| Dang these Jordans! | Dave Jones | Full Range | 56 | 14th May 2005 03:53 PM |
| Jordans in open baffle | xcortes | Full Range | 2 | 5th November 2004 06:08 PM |
| Jordans on ebay uk | bobhayes | Multi-Way | 0 | 23rd October 2004 04:02 PM |
| Page generated in 0.10063 seconds (80.50% PHP - 19.50% MySQL) with 10 queries |
