Hi all,
Can one tell how good is this speaker by just looking at these specs? Is it worth building one with this? Thanks. 6.5" Double Cone Full Range (4ohm or 8 ohm available). - Cellulose Paper diaphragm with rubber surround - Up to 18kHz - High efficiency with balanced frequency response and very good low-mid. ACOUSTICAL DATA Rated Musical power: 35 W Short term maximum power: 75 W Rated impedance: 4 Ohm Resonance frequency Fs : 55.000 Hz Rated frequency range: 60 - 18000 Hz Sensitivity : 92 dB TS PARAMETERS Acquired by MLSSA D-0-10 Effective piston area Sd: 126.700 cm2 DC resistance of voice coil Re: 3.600 Ohm Mechanical Q factor Qms: 2.640 Electrical Q factor Qes: 0.800 Total Q factor Qts: 0.610 Voice coil inductance Le: 0.3 Equivalent volume Vas: 23.000 l Moving mass (including air load) Mms: 8.200 g Suspension compliance Cms: 1022.000 uM/Newton Force factor Bl: 3.6 Tm Maximum linear displacement Xmax: 2.8 mm MECHANICAL DATA Voice coil carrier material: Aluminium Voice coil diameter: 25.4 mm Winding height of voice coil: 6.2 mm Yoke diameter: 25 mm Air gap height: 4.5 mm Magnet external diameter: 72 mm Magnet internal diameter: 32 mm Magnet height: 15 mm Compensating magnet external diameter - mm Compensating magnet internal diameter - mm Compensating magnet height - mm Weight 0.7 kg |
#2 |
No, you can't really tell what a driver sounds like from the specs. An SPL/frequency plot would help a lot. Given the Qts of .61, though, this one ought to give a fair indication of its potential in an open baffle. Since an OB is so cheap and easy to put together, its definately worth building one to see how it sounds (assuming the drivers are already in your possession or aren't prohibitively expensive themselves).
#3 |
Hi Hoyo,
Thanks for the reply. No, there aren't too expensive but I just do not want to put too much effort for little return. I like to build a horn for these. What do you think? |
#4 |
The Qts is pretty high for a horn-loaded design...
Jim J. |
#5 | |
Thanks! |
| IDE/ATA specs | NinjaKitten | Parts | 2 | 18th May 2009 11:21 AM |
| Re different than specs? | mitchyz250f | Multi-Way | 0 | 23rd March 2009 11:20 PM |
| in wall speakers and amplifier specs | dc2007 | Power Supplies | 0 | 21st September 2007 05:44 PM |
| 6 1/2 inch vifa from elan speakers any one know specs? | bruce ferrara | Multi-Way | 0 | 11th January 2007 01:46 AM |
| KLH dual cone speakers specs | MPM | Full Range | 0 | 25th August 2005 02:35 PM |
| Page generated in 0.08177 seconds (75.82% PHP - 24.18% MySQL) with 10 queries |
