Old 19th October 2009, 12:16 AM   #1
Default FE127E speaker with modified driver
not bad sounding speaker.
paperclips are inserted between cone cuts and glued with gorilla glue.
0.6mh inductor is used for BSC
measurement mic distance ~12in
Old 19th October 2009, 02:37 AM   #2
Godzilla's Avatar
Maybe the 127e needs a bit of mass loading to sound better?
Godzilla
Old 19th October 2009, 03:20 AM   #3
I forgot to add, that peak after 10k wasn't there before I tried to glue paper clips around cones' edges.
clips are removed, but peak is still there, I wonder if it is a gorilla glue's leftovers resonance I'll try to chip them off with cutters.
Old 22nd October 2009, 05:42 AM   #4
what happened to the forum? I can't edit my own posts.
spike is caused by resonance between copper tube, I inserted, and remaining pieces of dust cup. now when I removed most of the cap's pieces, that spike is much smaller.
it's fun to play them loud. cone is moving way abobe xmax, and yet, speakers are quite listenable, no "screaming".
Old 22nd October 2009, 05:51 AM   #5
frugal-phile(tm)
planet10's Avatar
You should still have the same 20 or 30 minutes it was before...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th October 2009, 06:22 AM   #6
BudP is offline BudP  United States
BudP's Avatar
Good to see some original experiments with cones. And, a good cone to try it on too. Keep thinking.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
DIY speaker driver? hofffam Multi-Way 3 2nd February 2009 05:50 PM
TAD Driver in Fullrange Speaker jpetek Multi-Way 0 1st September 2008 03:08 PM
What PAWO driver ... other than FR125S or FE127E? Brisso57 Full Range 6 29th November 2007 07:34 PM
Re-use of old speaker driver William Multi-Way 1 24th October 2001 09:51 PM
Page generated in 0.09546 seconds (75.19% PHP - 24.81% MySQL) with 11 queries
