Old 2nd November 2009, 04:22 PM   #101
frugal-phile(tm)
planet10's Avatar
Originally Posted by chris661 View Post
I haven't measured anything - I don't have the equipment.
I only listened to the bass end (20Hz upwards), and, while 30Hz is audible, it's quite quiet compared to 40Hz. Chances are that this is partly room gain - 30Hz should be lower (in volume) than it sounds.
That is a measurement... crude, but still a measurement
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd November 2009, 06:48 PM   #102
chris661's Avatar
Let's not get into how it measures - that's not the point. The point is the sound. That's why many people out there love tube amps - they clip early, but they do it in such a nice way that people just don't care. This speaker, while I can't measure it and it's not what I designed it to be, is still a damn good speaker, therefore I'm keeping it the way it is.
[/rant]
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 2nd November 2009, 07:23 PM   #103
frugal-phile(tm)
planet10's Avatar
I don't argue that at all... just commenting on the the modeled behavior.
I don't usually measure until i'm haapy with the sound (except when i'm doing traditional multiways -- XOs need the iformation input)
dave
Old 3rd November 2009, 07:17 PM   #104
chris661's Avatar
This weather is ironic - when I get some time to build a speaker, it rains. When it goes dark, it stops.
At least it means Christmas is here soon...
Chris
Old 9th November 2009, 06:30 AM   #105
chris661's Avatar
Worked well into the evening yesterday, and got the second speaker finished.
All I can saw is wow! I don't think I've listened to anything better than these... Bass goes lower than the size of the drivers would suggest, and the mids and highs are just so... natural, lifelike, and they get the sound of instruments right - cymbals sound metallic etc, so it's all looking good atm.
There's just one thing that's annoyed me now - it takes most people many years to get some speakers they're happy with. I've fluked it, but now what? Do I go on to build amplifiers? Or keep making bigger/smaller versions of the one I just made?
Chris
Old 9th November 2009, 07:30 AM   #106
frugal-phile(tm)
planet10's Avatar
You could start practicing...
EnABL - Listening impressions & techniques
dave
Old 9th November 2009, 01:02 PM   #107
Jim Shearer's Avatar
Glad you're satisfied with your first build--but so what? Just because you like those speakers is no reason to stop. I was happy with my first build, and that didn't slow me down. I planned to do two builds this summer. Ended up with four. And Martin has me working on designs with his MathCAD worksheets now. There is no end to the madness...
Cheers, Jim
A day without music is like a day without food.
Old 9th November 2009, 02:43 PM   #108
chris661's Avatar
Thanks for the encouragement. I suppose I could knock up some matching satellites...
Dave, as you'll probably have gathered, I've got lots of paper cone FRers, so it looks like a kit will be winging it's way to me shortly...
I think my next (really major) build will be when I have my own house. I'm thinking have a big, central amplifier, and a pair of speakers in each major room... I'm hoping for an open-plan space, so sound travels well... Thinking pair of subs with a 15" woofer each, then something a little smaller for mains etc... (This will be in a few years though)
Chris
Old 10th November 2009, 04:09 PM   #109
chris661's Avatar
I'm changing amplifiers around. The most powerful I have is an all in one 75W/ch, but these Watts aren't real watts - you get loads extra treble at vol 25/31, but the last 4 units on the volume control is where most of the gain is (it's a digital amp).
My next amp is one I got from school (they were going to bin it...), which I took apart and discovered it had a massively under-done PSU, so, a pair of 4800uF caps later and I have an amp that can use all it's volume control (into 8ohm) with little (nasty) distortion. I think it's a class A, but I'm not sure. Definately an analogue one. 50W/channel, around 40 of which are useful.
I also have a little amp that I took from a pair of PC speakers (got bored one day), which gives approx 7W/ch into 4ohm. Around 3 of those 7 watts are of any use. Pretty sure it's class A - gets very hot in less than 1/2 hour's use, no matter the volume or impedance load on it.
So far, the best sounding one has been the CD player, but the maximum volume has been limited severely by the fact that it adds way too much treble when you turn it up. My favourite is the amp from school, simply because it can go louder, and still sounds pretty good. Looks like a new (really good) amp is in order for Christmas/Birthday.
Chris
A thread for Tysen and variations on FAST planet10 Full Range 176 19th January 2012 03:05 PM
Famous Brazilian Amplifiers mod_evil Solid State 47 17th November 2008 11:10 PM
1 pair of Seas W15CY current version for sale cheap Jed Swap Meet 8 4th April 2008 04:17 PM
famous names ... tomtt The Lounge 2 8th September 2007 03:01 PM
Cool speaker cables, the famous CAT5 promitheus Multi-Way 4 25th May 2001 12:52 AM
Page generated in 0.10033 seconds (81.66% PHP - 18.34% MySQL) with 11 queries
