Old 25th September 2009, 03:07 PM   #1
type is offline type  United States
Default Tang Band W3-1401sd; am I missing something?
Just checking out this driver on Parts Express and can't figure out how this driver can claim an Fs of 75hz. Based on the manufacturers provided response curve it looks like it's dropping off well before 100hz.
Here's a link to TB's spec sheet:
http://www.parts-express.com/pdf/264-887s.pdf
Old 25th September 2009, 03:56 PM   #2
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
seems OK. fs is determined from the maximum in the impedance curve. and with the low qt value, the early roll off can be expected.
btw: finally a TB 3" with a usefull Xmax!
Old 25th September 2009, 03:57 PM   #3
Scottmoose's Avatar
Edit -you beat me to it. Anyway, concurred, it looks fine to me, based purely on the manufacturers published sheet linked to. Impedance peak on the spec. sheet indicates Fs is at the 75Hz stated, & the mass corner of 2Fs/Qt = 483.87Hz matches the FR curve.
Old 25th September 2009, 04:10 PM   #4
Thanks for clearing that up.
So this one should have the high frequency performance of a 3 incher with the bass output of a 4 incher (same Fs as the 4 inch bamboo driver). Except for the low sensitivity it looks like a great little driver.
Old 25th September 2009, 05:54 PM   #5
tpsorin is offline tpsorin  Romania
Manufacturer response curve is usually on open baffle. You can get more bass by using horn or bass-reflex enclosure.
Old 25th September 2009, 09:27 PM   #6
Godzilla's Avatar
>>> So this one should have the high frequency performance of a 3 incher with the bass output of a 4 incher... Except for the low sensitivity it looks like a great little driver.
Yes, that's the usual trade off.
Godzilla
Old 26th September 2009, 02:54 AM   #7
lepomis is offline lepomis  United States
Did you get a look at this one? Wish I had a few extra bucks lying around to compare them to each other.
http://www.parts-express.com/pe/psho...20&ctab=2#Tabs
Old 29th September 2009, 05:57 PM   #8
badman is offline badman  United States
Custom Title
badman's Avatar
The Mark Audio are much more intriguing to me than either of those. Tang Band has yet to win me over, they have too little consistency, too many models, and don't seem to spend much time refining things before shipping.
Their 8" fullrangers do seem superb though.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 29th September 2009, 10:30 PM   #9
tinitus is offline tinitus  Europe
Interesting 5" I havent noticed before
http://www.tb-speaker.com/detail/1208_03/w5-704d.htm
Maybe this 4" could be worth a try
http://www.tb-speaker.com/detail/1230_04/w4-1720.htm
Old 30th September 2009, 09:46 AM   #10
Pit Hinder's Avatar
Send a message via ICQ to Pit Hinder
Henkjan,
>finally a TB 3" with a usefull Xmax!<
Don´t fall into that trap unless you´re talking car subwoomphers. A driver pumping like mad is a driver loaded with LF it can no way convert into SPL. Back to the drawing board, have a dream about a horn really loading the driver.
tang band drivers paulfk Full Range 2 20th July 2009 02:44 PM
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 06:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
Page generated in 0.10227 seconds (78.07% PHP - 21.93% MySQL) with 10 queries
