#11 | |
really?
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#12 |
For really real. I can't learn a language in a class it just doesn't work for me if I have no one to talk to.
#13 |
"Fakes the record room"
Which record room? The vocal booth in L.A. or the concrete bunker they recorded the drums in in New York? Most recording "rooms" come out of a reverb device, or a plugin in your favourite recording software. This would be more interesting if the music was mixed on this system. Then the rooms (mixing and reproducing) might dissapear and you'll hear exactly what the mixer/producer heard. Which IMO is what we should be striving for. |
#14 | |
On the other hand convolution isn’t a problem today, if you transmit the dry recorded signal, we can convolve it on the playback side for reverberation. But we have the source signal for produce the first reflections from the model of the desired recording room. So we can fake its reflections correctly. The transmitting standard would be MPEG4, the principle is Wave field synthesis. Regards H. |
#15 |
I disagree syntheticwave because there is more to it than just 2 independent tracks in a stereo signal. Also I can't blame generated ambiance as being bad because I have heard some sloppy wet recordings done with mics as well as impulse based reverbs. I dunno if I exactly see an advantage to giving the person who plays back the tracks control over the reverb when on most recordings I hear the reflections are omnipresent while the sources are discrete in the signals already.
#16 | |
… also wrong keys particularry. ![]() I agree the reverberation is omnipresent, its spatial distribution hardly important for the detection of the source position. But the first reflections, that’s another case. Its time and direction are the most important cue for our perception of a sound event. We cannot simply merge it in two common channels. The difference in angle regarding the source position is the base of the acoustic “Attractions” in the genuine sound field. The goal of the Holophony principle isn’t giving the control to the listener; the goal is avoid misguiding cues, caused by first reflections on wrong times from wrong directions. Regards Helmut |
#17 |
Hi, Full Range Man, at first, congratulations for the olympic games in brazil. But the system isnt really mono, at least not more mono as any arbitary real source. The systen restore the spatial sound field in the same manner as the recording room builds up the spatial sound field. Regards H. www.holophony.net |
#18 | |
A big county is made with engineers and workers, the lawyers and athletes are dispensable, they do not build anything, just play with a ball and the lawyers as everyone knows are plagues of insects. Regards, Gustavo
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average. |
#19 | |
![]() Regards Helmut |
#20 | |
I'd wager that's there's a substantial population (citizens or not, and not including tourists) that don't, even as a second language. That's certainly the case in many parts of Canada - Hongcouver and Surrey to name just a couple.
| Huge Room, Concrete and Glass | ACFerguson | Multi-Way | 5 | 12th January 2009 02:33 AM |
| Huge sound, small room | bjackson | Multi-Way | 16 | 31st October 2005 01:58 PM |
| Huge list of speaker related URLS | wintermute | Multi-Way | 0 | 17th August 2005 01:51 PM |
| TEAC x-2000r record mode stuck. Record light flashes but won't play. Any ideas? | mistered05 | Analogue Source | 1 | 30th June 2005 01:51 PM |
| Huge Concrete speaker cabinets in foundation | Graydon | Subwoofers | 12 | 17th November 2004 04:53 PM |
| Page generated in 0.14815 seconds (80.78% PHP - 19.22% MySQL) with 10 queries |
