Old 16th September 2009, 08:38 PM   #1
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Default How to keep stuffing on top of driver in place?
Just like the title says...I'm going to add some polyfill above the driver in my BIBs, what did you guys use to keep it from falling down and getting in the speaker? I remember something on Boozhound Labs with eye hooks and string, making a net of sorts...might try that.
Thanks.
Jim J.
Old 16th September 2009, 09:05 PM   #2
Best tip I heard for this is take a net fruit bag (more commonly used for onions but also oranges) and suspend it like a safety net at the level you want to keep the poly. No need to weave string.
I am tweaking my BIB as well. What other interior treatments do you have? I have had felt behind the driver with mixed results but have not put much else inside except for the suggested one inch poly at the front half of the base to where the divider splits the area of the base. Rest of the horn exit is just wood.
(Also it helps to keep BIB questions in the main BIB thread. Maybe have Cal put it in there?)
Old 16th September 2009, 09:22 PM   #3
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
That is exactly what I did. I've attached it with staples and duct tape. If you want something bigger and/or tougher, you can either use light fencing wire or wide plastic screen, like the stuff sold to keep debris out of gutters.
pj
www.wildburroaudio.com
Old 16th September 2009, 10:34 PM   #4
Glowbug's Avatar
Nothing else for now. I've got some acoustic foam I was planning on using, I also need to cut out more of a chamfer on the back side of the baffle when I have the drivers out.
And finally mount those binding posts I've had sitting around here for a while...gah, I'm lazy
Jim J.
Old 17th September 2009, 01:18 AM   #5
I've used a 'sock' made of the netting used for a bridal veil to hole polyfill in place. I cut the netting to shape, loosely sewed the edges with dental floss, and used another piece of floss as a drawstring to close the end after stuffing. Works fine.
The difference between theory and practice is that in theory there is no difference between theory and practice, but in practice there is.
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? jarthel Parts 12 26th July 2007 09:08 AM
What stuffing, and how much? harrygrey382 Multi-Way 1 23rd April 2007 05:04 PM
Stuffing Dave Jones Multi-Way 3 4th March 2005 01:48 PM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 09:26 AM
Stuffing Howard Multi-Way 14 11th August 2003 03:07 PM
Page generated in 0.08396 seconds (76.47% PHP - 23.53% MySQL) with 10 queries
