diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Micro Mini Desktop Tower Plans (http://www.diyaudio.com/forums/full-range/151588-micro-mini-desktop-tower-plans.html)
roadsterdriver 13th September 2009 10:41 PM
After a lot of deliberation, I have decided to go with a single driver design.
Critera:
1) Small foot print
2) Good Sound
3) Nice to look at
This is what I have come up with, below. I will also mate it with a sub...
I would welcome your input. Sorry for the poor drafting :)
roadsterdriver 13th September 2009 10:48 PM
2 Attachment(s)
...or here, maybe?
Glowbug 14th September 2009 12:01 AM
Do you absolutely need the sensitivity of the Fostex driver?
Maybe a CSS FR125 in a miniOnken? http://planet10-hifi.com/fonken.html
Bigun 14th September 2009 12:34 AM
The proportions of the box look very nice, aesthetically pleasing. I prefer this taller shape to the typical desktop options.
I think an additional brace, vertical between front baffle and back, might be worthwhile.
The back of the box is not far from the rear of the driver, with the danger of sound reflections back through the cone - need some good felt lining back there ?
roadsterdriver 14th September 2009 07:55 AM
Originally Posted by Bigun (http://www.diyaudio.com/forums/full-range/151588-micro-mini-desktop-tower-plans-post1923071.html#post1923071)
Thanks. I have to admit, aesthetics is a significant consideration.
I though about that, then I though it was overdoing it. Your probably right. I'll put on in.
This is a concern. I actually drew one on paper where the back of the box sloped out as it went up. That is front to rear 4 inches at bottom and 6 inches at top. Do you think that would make a significant difference?
PS: I've already bought the drivers, thanks. So, driver considerations are moot.
planet10 14th September 2009 08:04 AM
Be warned that you will likely get some colouration from the proximity of the side walls to the driver.
dave
roadsterdriver 14th September 2009 08:54 AM
Originally Posted by planet10 (http://www.diyaudio.com/forums/full-range/151588-micro-mini-desktop-tower-plans-post1923267.html#post1923267)
dave
I am worried about that, but since I am not willing to go wider, I'll just have to see what happens. Thanks.
roadsterdriver 14th September 2009 09:34 AM
Do you think placing the port in the rear would make it better or worse?
planet10 14th September 2009 04:36 PM
Given the high aspect ratio, i'd leave it on the front.... if your desk is anything like mine....
dave
Pit Hinder 14th September 2009 06:32 PM
Hmmm, yup. Unless your desk is wall mounted - in that case a rear firing BR wouldn´t matter. Things being what they are, a bit of harmonics from the BR slot might even camouflage as bass. :DUsing a 15" might help, if you can get one into that nicely shaped enclosure...
Resources saved on this page: MySQL 18.75%
