Old 12th September 2009, 11:24 PM   #1
cjkpkg is offline cjkpkg  United States
Default one Fonken down, one to go...
I am building a pair of fonkens thanks to planet10 hi fi with Fostex FE127E drivers. I have almost finished one cabinet at least to the point where I can hook it up and see what it sounds like. I must say that I am very impressed. On the other channel is a Polk M4.5 with a 6.5" driver and a tweeter. The Fonken has a distinctive warmer sound that impresses me. The bass seems to equal that of the polk. I do have a BSC hooked up at the moment for about 2dB correction.
I can only imagine what they will sound like when the cabinet is totally finished.
Please remember that this is just a temporary hookup...
Old 14th September 2009, 12:23 AM   #2
OK,
I have both cabinets to a point where I have them hooked up. I have the BSC hooked up and the backs have the the terminal blocks installed. The back panels, however, are not glued up yet.
I must say that this little cabinet/driver combo is awesome. The bass definitely outperforms my Polk M4.5's. Probably get even better once the backs are sealed.
Next up, maybe some towers...
Old 14th September 2009, 01:21 AM   #3
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Looking good
Jim J.
Old 14th September 2009, 05:30 PM   #4
chrisb is offline chrisb  Canada
these will sound best( i.e. soundstage/imaging) oriented vertically, and not within a bookshelf (i.e. stand-mounted at least 1.5-2 ft from any side or rear wall boundaries)
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 14th September 2009, 08:38 PM   #5
I will have to see if I can drop the shelves down enough to rotate them up...I am at SWMBO's mercy - and lucky I got this far...
Old 24th September 2009, 04:04 AM   #6
Well, one is really "down" now. I am in the final stages of a 3886 chipamp and everything checked out before I hooked the speakers up. Apparently there was one resistor that either broke loose somehow when I was jostling everything around or clamping the heat sink in place...anyways...the left channel started playing beautiful music through the fonken. Went to connect the right channel and snap crackle pop...wasn't enough to blow the fuse but enough to fry the driver. Crap!
Fixed the resistor problem and been listening with my old speakers for the last hour and a half and it sounds great. Running an Aikido tube preamp into either a Tubelab SimpleSE or this new LM3886 chipamp.
Old 24th September 2009, 07:01 PM   #7
ouch - been there too - yup, part of the thrill of DIY SS amps -it doesn't take even all of the DC supply rail across the speaker outputs to let the smoke out of a lot of the higher efficiency drivers.
Old 25th September 2009, 02:24 AM   #8
heck...at least it was the one with the dented dustcap
got my ship notice from madisound today...be back in business in a couple days.
fonken floostander MK... Gomoo Full Range 2 22nd January 2009 12:32 PM
Fonken-- my 4th build Jim Shearer Full Range 47 13th September 2008 06:23 AM
fonken build mantisory Full Range 16 26th August 2008 04:39 AM
Finally done, Fonken kazoo Full Range 13 21st November 2007 09:45 PM
Fonken questions jayme Full Range 2 16th October 2007 11:27 PM
Page generated in 0.10239 seconds (84.38% PHP - 15.62% MySQL) with 10 queries
