Old 12th September 2009, 02:47 PM   #1
oublie is offline oublie  United Kingdom
Default horn loading and multiple speakers
would a horn loaded line array function with an improved or reduced combing effect due to diaphram centre distance? What im thinking is that above the 3khz point or thereabouts on a 4 inch speaker array combing begines so would a horn design counteract this due to reflections withing the horn? also what would be the implications regarding high frequency response?
thanks.
Old 12th September 2009, 09:59 PM   #2
mwmkravchenko's Avatar
Default This depends on a couple of things
You could for instance create a horn with a narrow throat that would push up the available high frequency response limit from the horn itself. This is generally the case with mid to high frequency horns. They use a narrow throat to push up the frequency where the reflections from the horn cancel out the sound reproduced by the driver. But you still get problems with the limited response available from a given horn configuration. As in how large a horn do you want to get into building? Are you willing to trade off ease of build for performance.
The good news.
But in a line array you get stupendous efficiency if you use enough drivers. The choice you gave of a 4" driver is a good one. Your combing effect will indeed start around 4 to 6khz but in general it is not very noticeable. This is due to the fact that you are generally listening at least 6 to 8 feet away and the combing effects lessen as you move away from the baffle of the speaker enclosure.
So short answer. Don't worry be happy!
Your line source with the right drivers and enough of them will do everything you want.
Mark
Mark
Old 12th September 2009, 10:19 PM   #3
GM is offline GM  United States
GM's Avatar
Only until its throat induced beaming, so its compression ratio will limit HF BW without either a phase plug or a suspended HF horn in front of each driver. You can focus the array though and use the horn to control its directivity, but this is no trivial pursuit to get right and tends to be huge for the line length, so DSL appears to be using a combination of old diffuser technologies (JBL's plate diffuser and WE's horn within a horn) for wide BW control of their Synergy GH-60 line array horn system. What was once old is yet new again.
Bottom line, AFAIK there's no way to do a good job without excessive 'coloration' (distortion) going hand-in-hand, so other than as an experiment, not something I'd consider for HIFI, though probably fine for HT.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Two drivers loading the same horn. Tyimo Full Range 23 20th February 2009 03:19 PM
Horn loading a built sub qguy Subwoofers 3 25th October 2008 10:32 AM
Help with horn loading Web Wolf Multi-Way 3 25th October 2006 06:38 PM
horn-loading: 100% efficiency ?! e-side Multi-Way 54 1st August 2006 02:42 PM
Page generated in 0.07072 seconds (70.63% PHP - 29.37% MySQL) with 10 queries
