Old 10th September 2009, 07:28 AM   #1
Default Volume of FF85K for internal box size calculations
Does anyone know the volume of basket, magnet, etc (ie in-box volume of driver)for the FF85K?
I've got some on order, but it will be a while before they get here.
Thanks.
Old 10th September 2009, 06:23 PM   #2
chrisb is offline chrisb  Canada
Thanks.
not much
My grade 8 math is a bit rusty, but here goes - calculating the volume of a cylinder with the diameter of the magnet, the gross volume (i.e. from rear of mounting flange to magnet) would be pi*R^2*H = 31.76 cu in/ .018 cu ft or .52 liters
Remember that this is a very shallow driver (i.e. net mounting depth of 43mm = 1.69") ) - if front mounted on 3/4" baffle the driver will "intrude" into the cabinet by less than 1" , almost all of which is magnet. The numbers for that would be approx 17.67 cu in, .0102 cu ft or .28 liters.
I'd recommend taking any/combination of several methods to ensure clearance of basket frame/ magnet to the mounting baffle; i.e. rebating, separate mounting plate of thinner material (1/2" or less - say 1/8" aluminum or ABS) or champhering of the rear of driver cut-out on thicker material.
Whatever mounting method you choose, unless you're contemplating a very small enclosure, the volume consumed by the driver is minimal, and could certainly less than any cabinet bracing that might be employed.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 11th September 2009, 06:04 AM   #3
The whole box is gong to be 1/2" actually, desktop bipole.
So, 3.6L box with two drivers. So, I think volume of bracing and drivers might be fairly critical.
I guess I should have thought about it as a cylinder and done the calcs before asking. I seems like this would be available from driver specs. Maybe no because of different baffle thicknesses. Anyway, Thanks.
Old 11th September 2009, 09:44 AM   #4
Just got them in.
Wow! These are small!
Old 11th September 2009, 09:54 AM   #5
Just got them in.
Old 11th September 2009, 03:38 PM   #6
Well, my number was a very rough quick calculation - Mr Dlugos had actually arrived at a much more accurate figure for the driver volume as part of his design for a small desktop monopole for this driver - perhaps he can pipe in with that number.
I don't want to assume anyone's experience with this driver - it might seem that 1/2" material would be more than adequate for enclosure construction, but don't underestimate the power of its motor. While the X-max and Fs are certainly limited compared to larger drivers, it can still shake a poorly braced box.
In the case of the enclosure design referenced above, 1/2" BB plywood was used, along with a horizontal holey brace connecting the back of the magnet to the rear panel. In addition, the full width port slot panel and full depth spacers provide a fair degree of bracing. Indeed, the funnest part is applying the (felted cotton) panel damping in the fairly tight confines of a 2 liter box.
http://homepage.mac.com/tlinespeaker...en-0v9-map.pdf
Old 11th September 2009, 03:39 PM   #7
Just got them in.
they certainly don't sound that way though
Old 11th September 2009, 04:57 PM   #8
frugal-phile(tm)
planet10's Avatar
The amount used up by the basket & the cone is very close to the volume gained by mounting them on an opened up 12mm baffle, so in the end one needs to just calculate the amount taken up by the magnet. I used 0.09 litres for this. The holey brace in the uFonken takes up 0.116 litre. All of this is calculated into the net volume of uFonken
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th September 2009, 05:26 PM   #9
not much
Whatever mounting method you choose, unless you're contemplating a very small enclosure, the volume consumed by the driver is minimal, and could certainly (be) less than any cabinet bracing that might be employed.
intuitive
dave
analytical
and that's not a particularly big brace
note that the driver brace is not indicated in the 3-D phantom view on linked drawing, but as shown in section and plan views, is 102mm wide by approx 84mm deep(depending on depth of front baffle, and whether rebated)
Old 11th September 2009, 05:41 PM   #10
...don't underestimate the power of its motor. While the X-max and Fs are certainly limited compared to larger drivers, it can still shake a poorly braced box.
I'm going to use 1/2 MDF or Bird's Eye Maple, depending on availability and price. Definitely with bracing, even though I'll be listening at low SPLs, I want the best sound possible given my constraints.
I was thinking stuffing. Is felt better for a tiny box?
Internal volume dimensions abbster Multi-Way 2 21st June 2008 08:09 AM
Should box linings be included in volume calculations? Brisso57 Multi-Way 5 21st December 2007 08:00 AM
Minimum Internal Chassis Size For Audio Sector LM3875 Kit CarlosT Chip Amps 4 8th November 2006 02:11 AM
Midrange Internal Volume in a 3-Way 69stingray Multi-Way 5 9th November 2005 07:33 AM
What Internal Volume for a guitar cab? Mind Riot Multi-Way 4 24th February 2004 09:55 PM
Page generated in 0.12236 seconds (81.82% PHP - 18.18% MySQL) with 11 queries
