Old 1st September 2009, 07:03 PM   #1
IG81 is offline IG81  Canada
IG81's Avatar
Default TL alignement question
In a TL alignement with SO = SL, if the (constant) cross-sectionnal area is diminished, what would be the effect?
I would think it'd increase the acoustic impedance, further load the driver and add some damping to smooth the low frequency peaks, at the expense of LF output. Does that make sense or is it another story completely?
IG
Old 1st September 2009, 07:31 PM   #2
Scottmoose's Avatar
I'm not sure I entirely follow what you're describing (not at my most awake this evening) -are we talking a reverse-taper line here, i.e. one that narrows toward the terminus? I can't quite see how the area of a constant cross-section line can diminish otherwise; by defininition, it's constant, with a throat & terminus sharing the same CSA.
Old 1st September 2009, 07:34 PM   #3
IG81's Avatar
Assuming we are indeed talking about a reverse-taper line, then if you hold Vp constant, Fp is reduced for a given length (you could say they're inherently mass-loaded), gain also reduces, & you will typically see an additional reduction in the amplitude of harmonic resonances. Conversely, a positive-taper line (expanding toward the terminus) will exhibit a higher Fp & gain for a given length than a constant CSA or reverse-taper line, as it's essentially a conical horn & therefore it's resonant behaviour is that of, or approaches that of, a cone.
I mean a non-tapered line, thus SL = SO. By "constant", I meant it "constant throughout line lenght", sorry if it was confusing. What happens if the cross-section is diminished, so both SL and SO would be made smaller by the same ammount, leaving all else unchanged.
IG
Old 1st September 2009, 07:52 PM   #4
Scottmoose's Avatar
Ah, right.
Well, like anything else, a TL needs a minimum volume (Vp in this case rather than Vb). The pipe always resonates at a specific frequency determined by it's length; that's inherent. However, as you reduce the CSA LF output will become progressively 'strangled' by the lack of volume. See the attached -undamped of course, for clarity. Once you start damping it, things just get worse.
BTW, I junked the last bit in my first post as it was of no use.
Old 1st September 2009, 08:20 PM   #5
IG81's Avatar
Ah, right.
Thanks, I think I understand better.
Can you tell me what was the magnitude of the CSA change from top to bottom graph in your example?
I would have been looking to diminish CSA in my alignement to 25% of what the MJK alignement prescribes. Might be a tad much.
IG
Old 1st September 2009, 08:59 PM   #6
Scottmoose's Avatar
Those were very much generic, so don't expect the same to apply in all situations. For information though, the lower graph shows a pipe 1/3 the volume of the top. Mr Sod's Law decrees that demonstrations never turn out as well as you'd like, and in this particular instance, the length / CSA / driver I happened to use probably weren't the best examples. Remember too, that things rapidly get worse when damping is added to the smaller CSA pipe.
Less obviously, what the machine doesn't show in addition to the above is the severe subjective 'strangling' that the undersized pipe causes once damped sufficiently to smooth the response out to an acceptable level, particularly WRT dynamic BW & transient attacks.
25% is a pretty hefty reduction; I'd be very cautious there. As well-known an engineer as Joe d'Appolito fell foul of that one when he designed the Thor TL for Seas. Bad idea.
Old 1st September 2009, 09:04 PM   #7
IG81's Avatar
Yeah, I thought it was kinda steep. I would have liked the outlook to be a bit brighter, as material availability and cost would blow this project's low price point aim through the roof were I to stay with 100% prescribed CSA. I'll look into other solutions.
Thanks!
IG
Old 1st September 2009, 09:50 PM   #8
Scottmoose's Avatar
OK, what driver[s] are we talking about here? System? Room? Material played? Goals? They all have a bearing, but we can probably help out.
Old 2nd September 2009, 01:17 AM   #9
IG81's Avatar
Hehe, OK, if you must know...
It's mostly a case of feeling I need to do something with stuff that I have in a box. Room? Nothing planned, could even change building a few times! Music? Probably extremely varied, or whatever would end-up sounding good. Main goal, to build something at least half-decent (for which I need at least a good feeling of the design from the start which is not the case so far).
I posted in this forum looking for TL info as it seems to be a specialty of the Fullrange folks, but my project is not fullrange, but two-way. I'll still talk about it briefly, keeping to a minimum the 2-way stuff.
I have a nice pair of Vifa C13WG-19-08 that were grabbed for peanuts and some HT26 horn tweeters. I wanted to mount them into a TL, but since I don't have a garage anymore and don't want to work wood too extensively, I thought I'd mount them into ABS pipes, ¼ inch walls.
My alignement prescribed a CSA close enough to that of an 8" pipe. Over here, that size is not available in normal stores, can only be ordered with big plumbing supply places and the cost is rather prohibitive. Even 6" diameter is out of my budget. 4" is what I was looking at, being the standard, easily available and not to expensive.
I want to throw together something quick and cheap ($) that has at least an OK potential to sound decent, but what we're looking at with 4" pipe instead of 8" (25% of CSA) is not very enticing, IMHO.
So that's where I'm at now!
IG
Old 2nd September 2009, 05:03 AM   #10
GM is offline GM  United States
GM's Avatar
What about concrete column tube formers, AKA Sonotube? Really, if looks aren't a big deal, then making them out of heavy corrugated cardboard
Anyway, with a high Fs, low Vas and medium Qts, significant BSC plus designing based on a Q = 2 is required to get any LF out of it with a considerable loss of efficiency as the trade-off.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
do i REALLY need a crossover?? and an amp question. and an ohm question legendaryfrog Multi-Way 4 29th October 2006 01:39 AM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Time alignement fundamentals Kjetil Multi-Way 28 31st March 2004 06:35 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.13142 seconds (79.69% PHP - 20.31% MySQL) with 11 queries
