Tang Bang W8-1772 Impressions. - Page 45 - diyAudio
Old 24th April 2013, 08:29 PM   #441
freddi is offline freddi  United States
freddi's Avatar
"BR" = "bass reflex" FWIW 1772 sounded nice in a little Karlson type
1772
Audio Nirvana stamped-frame Super 8
Old 25th April 2013, 03:25 AM   #442
Mike B1 is offline Mike B1  United States
Mike B1's Avatar
They all look the same in the beginning eh?
Old 25th April 2013, 11:24 AM   #443
Datubie is offline Datubie  United States
Datubie's Avatar
BR=Bass reflex. Is that a kit or did you design the enclosures yourself?
Originally Posted by Darkheart View Post
Datubie, what did you mean by "What BR enclosures"?
Old 25th April 2013, 11:34 AM   #444
I Know, what BR means. But I didn't understand what were you asking.
Yes, I designed them myself. Enclosure width and depth was chosen to fit on my subs.
Old 25th April 2013, 03:41 PM   #445
Datubie's Avatar
Ok. I have a similar idea for mine.
Old 3rd May 2013, 12:02 PM   #446
Originally Posted by Bob Brines View Post
I used 1.5mH||15Ω. I found that this helped with the baffle hump as well as baffle step. Note that I typcally have the driver 24" from the front wall and several feet from the side walls. I also use 2μF=5Ω across the driver. This brings down the rising response nicely and removes any spittyness from the speaker.
YMMV
Bob
Bob,
didn't you mean 1.5mH||5Ω instead of 1.5mH||15Ω? I don't know almost nothing about passive circuits, but I have calculated 4db BSC for 11" wide baffle and got L=1.5mH and R=4ohm. How do you get 15 ohms?
I used this for my calculations: mh-audio.nl - Home
Old 3rd May 2013, 12:11 PM   #447
Bob Brines's Avatar
Bob,
Try it both ways. See what works for you. When I test a speaker, I use an L-pad in place of the resistor and play with it until I hear what I want. Measure the L-pad and use that value resistor. (I also have a variable inductor. I took a 5mH Erse Super Q and unwound it, then rewound it with taps every 0.5mH 1.0-4.5mH.)
Bob
Old 5th May 2013, 10:22 AM   #448
Bob, I am not sure, if I understand you correctly (I'm not familiar with passive circuits at all). Do you use something like that?
Won't this bring down speaker sensitivity to much?
Old 10th May 2013, 08:36 AM   #449
So I tried this circuit with similar values:
Lbsc 1.5mH
Rbsc 13.2ohm
Rz 4.7ohm
Cz 2.2uF
This is what I get:
The response looks more linear but really sucks out life of music. Enclosure - 40l bass reflex tuned to ~63hz.
In parametric equalizer I used low shelf+3db and high shelf-3db @414hz with Q 0.7 and liked the sound. I would like to get passive circuit close to this. Any suggestions?
Old 10th May 2013, 12:49 PM   #450
Bob Brines's Avatar
Ah, yes. The problem with a dead flat response. Enter loudness EQ. Seemingly by nature we like to hear a smiley face EQ. Warm, bassy with a bit of tizz. The softer you play the speakers, the more EQ you want to hear.
You see why I advocate digital EQ. You can be much more precise with the EQ, and you don't have to solder in new parts to change it. You don't want a flat response, you want a smooth response. The lowest point of the FR should be ~2kHz -- the BBC dip.
BTW, I thought I answered you question about the filter reducing SPL, but I guess it got lost. Yes, a BSC filter reduces the ultimate SPL. Manufacturers tend to use the 1kHz FR level as the published "efficiency". It's often a lie. The real sensitivity it the ~100Hz response. Using your uncalibrated no filter FR, The 1kHz level is 9odB and the 100Hz is 85dB. That is a drop of 5dB and that is very normal.
Bob
NEW Full range Tang Bang NihonJR06 Full Range 3 10th March 2009 11:13 PM
MLTL help with Tang Bang W4-1320S Estes Full Range 2 21st November 2008 06:10 PM
Design Review: Tang Bang W5-704s Woofer 69stingray Multi-Way 80 20th May 2008 07:45 PM
A 2 way using the Tang Bang 4" bamboo driver? saabracer23 Multi-Way 25 6th March 2007 04:18 AM
Help me choosing a tweeter for my car (tang bang versus vifa) Mogar Multi-Way 2 12th January 2006 11:59 AM
Copyright ©1999-2017 diyAudio
