Tang Bang W8-1772 Impressions. - Page 3 - diyAudio
Old 1st September 2009, 02:05 PM   #21
Default Response Plot Questions
Bob,
These drivers sure look promising: relatively even frequency response and T/S parameters allowing reasonable bass in manageable enclosures.
Regarding the response plots, are they for the raw driver or are your BSC and HF correction networks included? I wonder how audible the two HF peaks and the suckout between 4.5 and 6.5 kHz will be. The curves for 15 and 30 degrees off axis look very promising.
Thanks for taking the lead on this.
Bob P.
Old 1st September 2009, 04:14 PM   #22
Godzilla's Avatar
>>> Now one stretched out so the details are visible:
Many thanks Bob! The only thing i don't like about the measurements is the dip at 150hz... otherwise it looks great.
Godzilla
Old 1st September 2009, 07:00 PM   #23
Bob Brines's Avatar
Originally Posted by AstroSonic View Post
Bob,
....Regarding the response plots, are they for the raw driver or are your BSC and HF correction networks included? I wonder how audible the two HF peaks and the suckout between 4.5 and 6.5 kHz will be....
Bob P.
No BCS, No EQ. The driver is in an MLTL, not on an EIC baffle.
The 4.5kHz notch only starts to appear in the 30* plot, so at normal listening angles -- 10-15* -- it is probably not an issue. The 6.5kHz notch coincides with the sibilance peak in most pop recordings. The effect is softening of the "s" and "p" sounds. Interestingly, this notch appears in every driver I have converted to phase plugs. I have to wonder if it is not the effect of the phase plug in THIS driver. The HF peaks are so narrow in terms of octaves, that you will probably not hear them. Look at these peaks as a continuing of the general rising FR.
Bob
Old 1st September 2009, 07:02 PM   #24
Bob Brines's Avatar
Godzilla
That dip is floor bounce. You should ignore anything below ~500Hz as artifacts of the cabinet.
Bob
Old 1st September 2009, 07:41 PM   #25
rdf is offline rdf  Canada
rdf's Avatar
Thanks for posting this, nice work & driver. Is the elevated frequency response above ~200 Hz a baffle step artifact?
Ears aren't microphones.
Old 1st September 2009, 07:52 PM   #26
Bob Brines's Avatar
Yep! That's what baffle step looks like.
Bob
Old 1st September 2009, 08:03 PM   #27
speakrsrfun's Avatar
Anyone have an idea what retail will be on these, they look good for next years project to be started in January LOL. Take care....
What was that?... I can't hear you I have a line array filling my ears.
Old 1st September 2009, 09:48 PM   #28
Bob Brines's Avatar
http://www.parts-express.com/pe/show...number=264-893
Bob
Old 1st September 2009, 10:22 PM   #29
Holger Barske's Avatar
There's a self-taken set of TSP on the German distributor's page: http://oaudio.de/Lautsprecher-Chassi...1772::664.html
Meets Bob's measurements quite nicely.
Best regards: Holger
www.holgerbarske.com
Old 2nd September 2009, 03:37 AM   #30
Thank you sir I appreciate it, good lookin out.
NEW Full range Tang Bang NihonJR06 Full Range 3 10th March 2009 11:13 PM
MLTL help with Tang Bang W4-1320S Estes Full Range 2 21st November 2008 06:10 PM
Design Review: Tang Bang W5-704s Woofer 69stingray Multi-Way 80 20th May 2008 07:45 PM
A 2 way using the Tang Bang 4" bamboo driver? saabracer23 Multi-Way 25 6th March 2007 04:18 AM
Help me choosing a tweeter for my car (tang bang versus vifa) Mogar Multi-Way 2 12th January 2006 11:59 AM
Copyright ©1999-2017 diyAudio
