Tang Band W8-1772 Impressions.
Old 21st March 2013, 10:00 AM   #421
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Why would he be kidding you? Presumably he knows the behaviour of his own subwoofers.
Back OT, I wouldn't care to run any kind of back-loaded box higher than ~300Hz; the group delay would drive me mad. FWIW though, much of that top-end peaking is there to provide better HF response off-axis, so if you angle them suitably, so you're not directly on-axis with the whizzer cones, the levels will start to balance out.
Old 21st March 2013, 11:07 AM   #422
Darkheart is offline Darkheart  Latvia
hm, thanks for your suggestions, but I prefer not to build new boxes. Your RDH20 looks very interesting, maybe I will build it a bit later - looks very promising.
Yesterday night I played a bit with high and low shelf of my equalizer plugin. I ended up with +4db at 400hz low shelf and -3db at 1khz high shelf using low Q values. Now my speakers sound much better.
I don't like my subwoofers crossed any higher then 75hz (now I use them at 65hz and mains fullrange), because bass gets slower and less tight.
Old 21st March 2013, 01:25 PM   #423
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Here are some RTA's I did. This is the unfiltered and filtered 1/2m response as I sell the speaker. In retrospect, I probably have the BSC filter set too low, but the parallel RC filter is working perfectly. Note that if you are 15* or so off axis, the rising response takes care of itself. This is typical of wide-range drivers.
As to the Q of the filters, I don't really know. I use the miniDSP and adjust things on the fly. I set the high and low shelves in the initial filter section and then take care of any other humps and bumps int XO filter section.
Bob
Old 21st March 2013, 03:36 PM   #424
Scottmoose's Avatar
Looks like a result to me.
Old 22nd March 2013, 03:04 AM   #425
Mike B1 is offline Mike B1  United States
Mike B1's Avatar
I built up a pair of these a couple of months back.
I have liked the sound of the TB full rangers since I did the neo 4" bamboo drivers 5 years ago. When I saw the stuff on the W8-1772 I got excited.
Didn't work for the HT system so I moved to the bedroom. Don't have a lot of space in the bedroom, so I put these into 24 liter net boxes tuned to 60 Hz with a 3" dia x 4" long port. According to win isd. Haven't verified the tuning. Put the vent behind a V brace so there was no direct path from the cone to the vent.
Lined the boxes with PE 3/4" sonic barrier foam and designed them so they would vent into the wall/ceiling boundary on hinged boards with turnbuckles so I could adjust the pan & tilt.
I am using just a modest zobel of 3.3 uF in series with 17 ohms across the driver and it takes the edge off. So far it works pretty good me thinks. I wanted to see if I could compensate for the early bass rolloff of a smaller box with the boundary gain of the wall/ceiling. So far, so good -
I want to do some measurements to verify, but I have no equipment. More stuff to buy.
Old 22nd March 2013, 01:54 PM   #426
Bob Brines's Avatar
Some comments based on my experience. Different box, different installations, so maybe not appropriation to yours.
I used 1.5mH||15Ω. I found that this helped with the baffle hump as well as baffle step. Note that I typcally have the driver 24" from the front wall and several feet from the side walls. I also use 2μF=5Ω across the driver. This brings down the rising response nicely and removes any spittyness from the speaker.
YMMV
Bob
Old 22nd March 2013, 02:19 PM   #427
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Bob
That's a nice looking freq response curve. Nicely done.
Old 31st March 2013, 03:01 AM   #428
Gary the Grey is offline Gary the Grey  United States
Thumbs up Nice picture!
Bob
That's a beautiful speaker Bob! I've been told that you did a small MLTL for the Fostex FE166En. Do you still have plans/pictures? Is there a build thread for that on the forum?
Old 31st March 2013, 12:30 PM   #429
Bob Brines's Avatar
Sadly, the FExx6En drivers proved utterly unsuitable for resonant cabinets. As soon as the FFxx5WK drivers became available, I abandoned the FE's. I lost my pair of FE166En's to a coating experiment, but for me, not great loss.
Bob
Old 31st March 2013, 12:59 PM   #430
Thanks Bob. I'll probably try to put them in a ported low resonance box like I usually build. That, or the recommended design that comes with the Fostex driver. But not if it's too big.
Tang Band W8-1772 Impressions.Hide this!Advertise here!
Tang Band W8-1772 FAST recommendations mayhem13 Full Range 11 24th March 2016 02:01 AM
Wanted: Tang Band W8-1772 drivers smallangryboy Swap Meet 0 2nd January 2013 09:28 AM
FS: Tang Band W8-1772 Full Range Drivers bikinpunk Swap Meet 3 15th November 2010 09:52 AM
Pair Tang Band W8-1772 New $220 Michael Rothacher Swap Meet 3 25th May 2010 01:39 PM
FS: Tang Band W8-1772 wideband drivers audiokinesis Swap Meet 2 21st February 2010 10:34 PM
