I am new to this forum but have been a devotee of full range efficient speakers for over 15 years. Three years ago I uprooted and retired to Portugal, for the weather and to play lots of golf. At that time I downsized and sold off my Oris Horn/ Onken setup and most of my amplifiers etc. Now due to serious illness I find I have lots of time to listen to my music again.
I am desperate to find a suitable full range speaker that I can built in the next 5 weeks before I go back into hospital for a major op. I can't seem to get over the loss of my Oris horns (Lowther DX4) and find I cannot listen to my electrostats as I loose interest in the music playing. As I am now a pensioner cost is an issue. Also to keep my other half happy I need a full range speaker that is no more than say 45" high and aesthetically pleasing. Additionally it must be happy being driven by either Single Ended 2A3's or SE 45 amplifiers. My room is 18.5'x13.5'x9' and I play both records and CD's. As I live in an apartment I try to keep levels below 85db. I have been considering the frugal horn and the Bryn. As I like my system to sound reasonably lifelike and portray the excitement of the music I feel there could also be other options that I should consider. Good bass is a must but deep bass is not that overly important to me.. Any suggestions would be very much appreciated. Russ |
#2 |
An inverted BiB can be built to a shorter height at the cost of some bass. If you can stretch, I think the Harveys are great, they sound very horn-like to me, and the profile is very narrow. I think the tough part is deciding which driver, as you don't necessarily need the highest efficiency if you're playing at lower SPL's.
Your stated height requirement would include lots of MLTL possibilities but if you are addicted to the horn sound, I would build a horn like the inverted BiB (or Harvey). |
#3 |
#4 |
I second Jeff.
Ask Dave for his recommendations and make sure you get the EnABL'd version of whatever the two of you come up with. You will never look back. Mostly due to paralysis setting in, from being unable to turn away from the drifts of music heaping up in front of you. Bud |
#5 |
Russ, after losing a few good too many friends and associates recently, I hope the operation is successful, and your recovery swift.
Call me biased, 'cause I've built more than a few of them, but the Fonken (prime) with FE127eN is probably still my favorite FR system, and with the (W)right SET amp and recordings, can be as Bud suggests, a portal to emotional connection with the artists. Well, OK, the F120A is really special, but not readily available - but more importantly not a great match with 45 or 2A3 SE, and barely adequate with 300B . However, any version of the Fonken prime is more that just a little bit of a pain in the a$$ to actually build (even after a couple of dozen pairs, the time just doesn't seem to get shorter) During the past 5 years or so, I've had the opportunity to hear the FE127 in more than a few enclosures, and as refined a match as the Fonken was for this driver before July of 2007, Mr Purvine is too modest to take the full measure of appropriate credit for unleashing upon us the ineffable "majik" of those little polka dots. Brynn, on the other hand, is pretty straight forward, doesn't occupy much more floorspace than the Fonkens with the requisite stands, and is still very enjoyable. Of course, none of these enclosures with the intended drivers will deliver the dynamics or sensitivity of your Oris system- but I think you knew that already. The Fostex FE126E is certainly worth consideration, but FWIW, based on my limited listening experience to BIB ( i.e. one sample only, with the FE108EZ, with which I'm familiar), the quality of bass is sacrificed for quantity. Either the Ron Clark A126 or Scottmoose Spawn design Saburo would be my suggestions for someone with the time on their hands (neither are a quick Saturday afternoon build) http://homepage.mac.com/tlinespeaker...lans260207.pdf http://homepage.mac.com/tlinespeaker...ap-0102008.pdf
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 29th August 2009 at 06:53 AM. |
#6 | |
The Fonkens might just do what I want. However I have a pair of superb near field monitors which I bought mid 90's which just don't do it for me so I am a little bit biased against bookshelf sized speakers. Also I must admit to still being a lover of the sound that a good Lowther setup can attain. Unfortunately I can't afford these drivers now. I therefore was tending to lean towards the Fostex Fe126e as I was thinking that this driver might be able to ring out a bit more of the excitement and emotion than the Fe127e. That was also the reason I thought the CHR-70 might be a suitable choice for me to work around. I think the Saburo would definitely be a speaker I would like but it is too large for me. Also I do not want speakers that require rear wall reinforcement as my room is exceptionally lively being all concrete, tiles and large ceiling to floor height windows. So that rules out the A126 and probably the Frugal Horns as well. So at this stage I have narrowed my project down to three possibles. I will try to overcome my bookshelf size speaker prejudices and further consider the Fonken. For ease I might just build the Bryn. However I have been taken with the microTower bipolar ML-TL with CHR-70. It meets my criteria for size and aesthetics. My PP 2A3 is exceptional and there is very little between it and my SE 2A3's. In fact most of my friends have actually preferred it to my single ended amps. So I look forward to you thoughts Chris after you try your castle ML-TL with various tube amps this weekend. |
#7 |
A pair of Fe127en drivers in Fonken's, mounted on stands, that put the drivers at about ear height, will throw a sound field from floor to ceiling and wall to wall, if the music contains that. The sound field will not be attached to the drivers. Instead it will erupt from the wall behind the speakers. Your listening position can be anywhere in the room, though the usual spot is best, even if only slightly.
These have nothing to do with book shelf speakers, and much to do with six foot tall maggies that have been set up correctly. And that is just the 127's. You might want to read this report for a gentle idea about the differences between 126's and 127's. Stock FE127E vs. planet10 EnABLed - Results I have a pair of 127's in Fonken boxes in my living room and they are making me very lazy about building my open baffles for Lowthers, which I do dearly love to listen to, once EnABL'd. 126's were just a bit too willing to go ballistic for my taste, but then so was a DX 4, I much prefer the PM6A. Bud |
#8 |
#9 | |
Based on what I've heard from Scott's design "Aiko", originally intended for a very disappointing little Lyeco driver, but since repurposed with very satisfactory results to the FE108EZ, I'd suggest either his Saburo, or Ron Clarkes' A126 for the FE126E
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#10 | |
Russ,
The guy who begged me to treat them has yet to figure out how to stand having them. He loves horns, but his Azura horn for the DX 4 was way beyond too much to listen to, so he mounted the DX 4's nude and put the horn on the back side. Alternately wrote about being on his knees praying for more bliss and running from the room in fear. The treated Fe126en's I did for Harry, out of the HornShoppe crowd, were pretty active. They did not have the Planet 10 pre treatment and certainly would have benefited from it, but politics wouldn't allow..... Bud |
| Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest | mbcouple | Swap Meet | 2 | 27th October 2008 10:27 PM |
| Reccomendations for smallish, cheap sub for FR drivers. | Spasticteapot | Subwoofers | 7 | 10th November 2006 05:23 PM |
| Smallish IB setup | Timn8ter | Multi-Way | 5 | 27th September 2003 02:11 PM |
| cheap sub for smallish enclosure | jkamps | Multi-Way | 0 | 1st August 2003 02:16 AM |
| Page generated in 0.15124 seconds (84.67% PHP - 15.33% MySQL) with 10 queries |
