Hi all,
I am thinking of having a go at a pair of full range active speakers based around an Audiosector LM3875 Gainclone kit. Any experience/thoughts would be much appreciated. 18mm MDF cabinets with a steel or aluminium sub chassis for the amp/psu section will be the chosen medium. I haven't settled on a driver yet, but I have a couple of ideas. For the amps, I intend to use 18-0-18v, 120VA transformers (rail voltage around 25V). I am just at the design/exploration stage of the project, so I won't be building anything just yet. I may even end up using the LM3875 modules and transformers from my power amp to save on cost (being a cheapskate Chris. |
#2 | |
Active usually means a multi way speaker controlled by an active crossover. Since a fullrange does not use crossovers - whats the point? |
#3 |
What a great idea! I have some JX-92's and a couple of ICEpower modules. I think I'll give it a go too. Of course that will be when my other projects are done. Too much on my plate right now :-(
Nihilism is best done by professionals. |
#4 | |
Chris. |
#5 |
Chris's definition of an active speaker is correct. Audio-kraut - you are thinking of an active crossover.
What's the budget for the drivers? You can get some really nice ones, but they do cost... Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#6 |
Since you'll be using longer than usual "interconnect" leads and the signals carried by them will already be attenuated, I'd reccomend fitting the active speakers with XLR connectors and a balanced line reciever inside. You then need a balanced line transmitter at your pre-amp. Using a passive attenuator with high output impedance and long unbalanced cable runs is likely to introduce a lot of noise.
#7 |
....and a gainclone wouldn't be my first choice for this application.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#8 |
Dr Em has a point. Long interconnects' capacitance driven from 10-25K impedance will roll off the top noticeably. You'd want to drive this from a low impedance preamp, or if passive, maybe a transformer-type attenuator. With a chip amp in the box you should get very good electrical damping of the driver. Downside is heat in the box from the power transformer & amp affecting the speaker's characteristics. Should be an interesting experiment.
#9 | |
I like the Gainclone sound. Detailed very detailed in the mid and treble, low distortion an not over blown in the bass department. An ideal candidate for a full range driver. I think it would be a worthwhile experiment. Chris. |
#10 | |
An F3 built as current source would offer pretty much the best of both worlds. Magura
| 16 Ohm Full-Range Speaker | thelordash | Chip Amps | 13 | 23rd January 2009 05:13 PM |
| Recommend a DIY full-range hi-fi speaker better than a 2/3-way one. | cirrus18 | Full Range | 34 | 13th December 2008 04:09 PM |
| full range speaker for HT | Jazzz | Full Range | 13 | 8th September 2006 08:27 PM |
| active crossover vs. full range | Vix | Multi-Way | 4 | 7th January 2004 06:37 PM |
| Active equalisation in full range speakers | niallsmart | Multi-Way | 20 | 7th October 2003 05:11 AM |
| Page generated in 0.10190 seconds (80.24% PHP - 19.76% MySQL) with 10 queries |
