Old 20th August 2009, 03:31 PM   #1
chris661's Avatar
Question 3" Driver in a Transmission Line.
As some of you will know, I've been using some Visaton FRS8s in open baffle speakers, using one in the baffle and one to cancel the rear wave.
I was curious about making a (fairly) small TL for them to see how they perform. Some say TLs shouldn't be tuned below driver Fs. If this is true for all projects, this will be a waste of time (Fs around 120Hz for this driver).
I am doing this to learn, as many like the sound of horn/TL speakers, and I wanted to know what made it so brilliant.
Link to the driver - http://www.visaton.com/en/chassis_zu...nd/frs8_8.html Parameters are also there. In winISD, they don't model hugely well (tried vented, sealed boxes), so I wondered what would happen in a more elaborate cabinet design.
Thanks in advance for any tips (even if it is simply to say "this won't work")
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 20th August 2009, 10:44 PM   #2
Chris, as I suggested to Kipman, personally, for something this small, I'd use an FRS8M as a full range (bit more efficient than the FRS8) & the WS130 for the low end (< 200Hz). You will only be able to get an EBS alignment happening for the FRS8, and to use eq to get reasonable bass level will push such a small driver beyond its capabilities. You'll get much less distortion going 2 way (& these drivers are pretty cheap...)
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 20th August 2009, 11:32 PM   #3
Zigis is offline Zigis  Latvia
Cyburgs-Needle is TL using frs8, very good bass for this small driver
Cyburgs-Needle for Tangband W3-871S
any links to your OB?
Old 21st August 2009, 09:43 AM   #4
chris661's Avatar
Yeah, got some links
design +messing around new idea? to eliminate need for BSC
my almost done design (starts around 1/2 way down) Ultimate OB GALLERY
Nice link there - I was searching through the full range forums for something like that and got nothing...
I have 4 with me, and can get a lot more if needbe (they're &#163;8 each here, but bulk buys are a lot cheaper).
Chris
Sonotube transmission line sub with Dayton RS driver bikehorn Subwoofers 0 8th May 2009 08:04 PM
Alpha Transmission line - can the driver be offset? adamt Multi-Way 3 26th June 2006 11:36 AM
Transmission Line - "C m/s" 10K2HVN Multi-Way 4 31st March 2005 08:17 AM
8" Quartz pipe for Transmission Line speaker MRehorst Swap Meet 0 26th December 2002 11:00 PM
Page generated in 0.07773 seconds (69.12% PHP - 30.88% MySQL) with 10 queries
