microTower bipolar ML-TL for CHR-70 or EL70
Old 9th December 2014, 05:10 PM   #601
cedricb is offline cedricb  Europe
@dave: any news regarding your bi-poles MT with a tweeter?
Old 9th December 2014, 05:23 PM   #602
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
We took CHR out of the bipole MT and fitted CHP70.2 and ERT26. Not up to the level of the EL70 or Chris' CHBW with ERT using DaveR XO.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th December 2014, 06:09 PM   #603
Cambe is offline Cambe
Are there any links for Chris's CHBW with the ERT using Dave R's crossover?
Old 9th December 2014, 06:32 PM   #604
frugal-phile(tm)
planet10's Avatar
There are posts and pictures, but i don't have links. The tweeters are nolonger available.
dave
Old 9th December 2014, 07:45 PM   #605
chrisb is offline chrisb
closest current equivalent would probably be something like these:
Creative Sound - Product Details
Bob has some factory blemish "seconds" at almost half price
quite a decent tweeter
The crossover designed by DaveR was through Bob as well.
like my mind, this space intentionally blank
Old 10th February 2015, 09:39 PM   #606
brookhart995 is offline brookhart995  United States
brookhart995's Avatar
Anyone every put a CHR 70.3 in a half tower? I have been trying to find a enclosure that I can use for a rear speaker. A solution I thought of was to build two of the half towers with the drivers facing up. Keeping the cabinet dimensions and porting the same how would that sound. I am planning to put these behind and to the sides of the couch and wanted to put the drivers facing up to diffuse the sound.
Old 10th February 2015, 09:41 PM   #607
frugal-phile(tm)
planet10's Avatar
That should work fine.
dave
Old 10th February 2015, 10:08 PM   #608
cogitech is offline cogitech  Canada
cogitech's Avatar
Yes, it'll work fine as planet10 says. I too prefer diffused rear channels.
However, I am not sure you will realize the benefits of a MLTL tower when used as as rears. In other words, do you really need a cabinet so large? The main point of the MLTL is to squeeze as much bottom end out as reasonably possible while maintaining coherence. Do you need that bottom-end in rear channels? If not, then you could get away with a small, sealed unit of whatever shape you envision.
EDIT: Wait a minute... I don't think there is room up top of a half-tower for CHR 70.3
Old 10th February 2015, 10:27 PM   #609
frugal-phile(tm)
planet10's Avatar
Not quite in this case. Part of the design breif for the microTower was to get as much bass as possible and retain the size of the original microTower from EPI.
If you want max bass Scott has a couple big ML-TLs
Now that is a very good point. Perhaps a folded halfTower with the driver faced up, or angle the baffle to have it not fire straight up at the ceiling (not a good idea if your ceiling isn't vaulted)
dave
Old 10th February 2015, 10:33 PM   #610
cogitech's Avatar
Dave, I was speaking of MLTL in general, not the microTower specifically. Point is, for rears there's just not a lot of low frequency stuff in the signal, so not much point in an MLTL.
I was looking at the folded half-tower, too, but again... for rear channels a simple sealed box of appropriate size would perform just fine, no?
microTower bipolar ML-TL for CHR-70 or EL70Hide this!Advertise here!
Offset Bipolar MLTL with CSS EL70 Drivers--Part 1 Jim Griffin Full Range 48 18th October 2012 04:24 AM
Introducing The new CSS EL70 CSS/XBL CSS 41 19th April 2010 09:23 PM
Bipolar electrolytics dsavitsk Parts 3 8th January 2006 10:48 PM
How does this bipolar look? punchpeanut Solid State 11 2nd October 2003 07:48 AM
