microTower bipolar ML-TL for CHR-70 or EL70
Old 17th May 2012, 07:16 PM   #471
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Robert,
How many plys in the plywood?
Except for issues with driver rebates, 12mm, with maximum bracing, would be fine, if the ply is of sufficient quality -- we have a pair of subwoofers (push-push SDX10) here that we did in 15mm BB just to see how far the concept can be taken (waiting for the 4 channel amp)
The act of adding an addiitonal layer will push you towards a higher quality material if done right (and with a press sounds like you are).
One ofmy gurus did extensive research into materials. He found that he wasn't happy with MDF, but very happy with a board he made from 7 layers of 1/8" MDF (he used a 10 ton press).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th May 2012, 07:43 PM   #472
zman01 is online now zman01  Bangladesh
dave
Very interesting. So layers count!
Old 18th May 2012, 05:29 AM   #473
leeoh is offline leeoh  Australia
Robert,
dave
There are 5 plys in the 12mm board and 3 in each of the 3mm. If I decide to go with the ply I will put the 3mm on both sides of the 12mm, to balance it. That will also give me a little more depth to play with when rebating for the speakers. I will also work to interior dimensions that you show for the enclosures, so the additional thickness of the sides won't make for a smaller enclosure. Robert.
Robert
Old 18th May 2012, 06:24 AM   #474
frugal-phile(tm)
planet10's Avatar
If you have the press, i'd be tempted to just lay up 5 thicknesses of the 3mm...
The local Home Despot sells some 3/4" with 5 plies...
BB has 9 in 12mm, the new Murphy ply we are using likley more -- the 15 (13 plies) & 18 (15? plies) both do.
the triple laminate should be good, the dissimilar material in the middle will go a long way to increasing the damping.
dave
Old 21st May 2012, 05:02 AM   #475
Dave I have more confidence in getting a decent job with the 12 ply centre and 3mm ply on either side than glueing five of the 3mm plies into one. I've tried doing that on another job and found the resulting piece was somewhat warped. Possibly something to do with the fact that the ply is not top quality (hence its price). Plantation grown pine can do strange things when wet! I've used 12mm particle board with 3mm ply on either side without any problems, so would hope that the 12mm ply centre would be the same.
Robert
Old 5th June 2012, 12:23 AM   #476
Dave. I'm part way thro' the build but am undecided about speaker placement. I rather like my Windermere placement of two EL70s facing outwards. If I do that with the Castles, how far apart should the speakers be on the forward facing baffle and how should the damping be fastened? Is a curtain from top to bottom, suspended diagonally OK? Should the bare inside faces also be covered? Thanks.
Robert
Old 5th June 2012, 05:25 PM   #477
frugal-phile(tm)
planet10's Avatar
Robert,
I don't get your question. The Castle is the arrangement of 1 driver on the front, the other on the top.
I like to line the panels in the vicinity of the driver, the diagonal curtain of ~3" insulation is a good starting point for damping.
dave
Old 5th June 2012, 06:11 PM   #478
chrisb is offline chrisb
Robert,
dave
Robert - the other variation of the dual driver MT enclosures that we've built to date is the "true" bipole - 2 drivers in push/push configuration opposite sides. Each format has its advantages, but for ease of placement and spacious soundstage, I quite prefer the "castle" version. Of course we used CHR70s in the bipole, and dual EL70s in an MLTL certainly punch further above their weight class in the low frequency department than the CHRs. .
like my mind, this space intentionally blank
Old 5th June 2012, 06:19 PM   #479
frugal-phile(tm)
planet10's Avatar
Soon to be reborn with CHP7-.2 + ERT26 tweeters, a MicroTower II as it were.
dave
Old 6th June 2012, 06:56 AM   #480
Robert,
dave
Sorry Dave, I thought that all the same sized enclosures, regardless of the speaker placement position were called Castle. I had thought of placing one speaker facing up and the other on the baffle, but liking the sound of the Windermere with both speakers facing forward, thought I could do the same with this enclosure. Not so? The holey brace placement would be more straight forward with both facing forward, but I can at this stage still put one on top.
Robert
microTower bipolar ML-TL for CHR-70 or EL70Hide this!Advertise here!
Offset Bipolar MLTL with CSS EL70 Drivers--Part 1 Jim Griffin Full Range 48 18th October 2012 04:24 AM
Introducing The new CSS EL70 CSS/XBL CSS 41 19th April 2010 09:23 PM
Bipolar electrolytics dsavitsk Parts 3 8th January 2006 10:48 PM
How does this bipolar look? punchpeanut Solid State 11 2nd October 2003 07:48 AM
