microTower bipolar ML-TL for CHR-70 or EL70 - Page 47 - diyAudio
Old 7th February 2012, 01:25 AM   #461
frugal-phile(tm)
planet10's Avatar
11' ceiling, nice
Should be interesting. That 1 factor is going to mess with anyone's guesses.
have to wait until I get everything in place
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th February 2012, 02:33 AM   #462
Originally Posted by planet10 View Post
11' ceiling, nice
dave
I figured that would make things a bit more interesting. Probably better than my current situation.
I am temporarily in a top floor loft apartment in an old converted mill with 16' ceilings. The wall where the speakers are placed right now tilts inward at about 20 and has two 8' tall garret windows. At one point when fooling around with speaker placement it sounded like Diana Krall was singing from the next room.
But in general, does the castle design limit distance from the wall?
(and everyone please note - due to WAF there will be no acoustic treatments other than normal furniture and art hanging on the walls in the new place.)
Old 7th February 2012, 02:36 AM   #463
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by bobtrancho View Post
... with 16' ceilings
I see a projector and big screen in your future, speakers to go with
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 7th February 2012, 02:43 AM   #464
frugal-phile(tm)
planet10's Avatar
I don't think so.
Inmy room, with the speakers undrt a sloped roof, they had to be out a certain minimum distance.
dave
Old 7th February 2012, 05:18 PM   #465
chrisb is offline chrisb  Canada
I don't think so.
dave
In my more conventional room ( 8ft ceiling) , the Castle MTs are about 8" from a the rear wall, flanking a large picture window - so there'll be some diffraction of early rear wall reflections - and about 10 or so degrees of toe-in. The latter is something you'll likely want to play with a bit to dial in the imaging sweet spot.
on hiatus
Old 12th February 2012, 03:59 PM   #466
Can I build these as is and use an original quad of EPI drivers as used in the MT-1's?
Old 17th May 2012, 07:00 AM   #467
leeoh is offline leeoh  Australia
Default Ausie stuffing and ply?
Have any of you Aussies used the 2400 X1200 12mm ply that Bunnings have in stock for $33 a sheet? The surface doesn't look bad at all but the existence of voids I don't know about. I had thought of using it and glueing some of their 3mm ply on both sides to bring it up to useable thickness for a set of Micro Towers. The alternative is to use 12mm particle board with the same 3mm ply glued to both sides. At least it is always void free in my experience.
What about stuffing? Jaycar have some which seems expensive and I don't know if it is OK or not. In the past I have used motor vehicle upholster's padding which seems to my untutored ears to be OK. Any alternatives?
Robert
Old 17th May 2012, 09:10 AM   #468
frugal-phile(tm)
planet10's Avatar
Worth a try. You will need to play with the tuning.
Or, if you leave thebottomoff, you have the original MT1
dave
Old 17th May 2012, 09:54 AM   #469
zman01 is offline zman01  Bangladesh
Robert,
Dave and ChrisB would know better, but both ply and particle board should work. If the ply is "mostly" void free, that should be ok. Gluing another layer of board is a pain, but 12mm is too thin for the Micro Towers. Do you have 18mm material available?
- Zia
Old 17th May 2012, 10:33 AM   #470
Zia. Thanks for the reply. I don't mind glueing the thinner ply to the 12mm ply. I've done quite a lot of veneering so I have a ready made, substantial veneer press for larger sections and have gone thro' the process with one of Scott's Windermeres. Very heavy when finished! The only 18mm materials here at a reasonable price are particle board and MDF- neither of which seem to be favourably regarded by Scott and Dave. I've used them both in the past but would like to give the ply a try. Robert.
Robert
Offset Bipolar MLTL with CSS EL70 Drivers--Part 1 Jim Griffin Full Range 48 18th October 2012 04:24 AM
Introducing The new CSS EL70 CSS/XBL CSS 41 19th April 2010 09:23 PM
Bipolar electrolytics dsavitsk Parts 3 8th January 2006 10:48 PM
How does this bipolar look? punchpeanut Solid State 11 2nd October 2003 07:48 AM
Copyright 1999-2017 diyAudio
