Old 4th March 2010, 09:12 AM   #111
leeoh is offline leeoh  Australia
Originally Posted by planet10 View Post
Yes,
The EL70 was the 1st driver Mark did with the tech that also gives the extended HF seen in the Alpair7 and Alpair12.
dave
Dave. Thanks again for your help.
Old 4th March 2010, 11:25 AM   #112
I build up 5.1 system around 5 CSS el70's. Main channels are BIB's, center- and back-channels are microtowers. With good subwoofer Price/quality ratio is great, specially in my case when I have separate set for music (2-channel listening.)
Old 4th March 2010, 12:20 PM   #113
Interesting speaker, certainly. So how much amplifier power is needed for an EL70 implementation? (And what is the efficiency of those drivers anyway?)
Old 4th March 2010, 03:27 PM   #114
frugal-phile(tm)
planet10's Avatar
I would recommend 10-20 watts minimum. Depends on levels required & room size. I have 20 w on mine at the moment, when Chris uses them, his big amp is 7w (my room is big, his is small)
http://p10hifi.net/planet10/CSS/EL70...ata-080909.pdf
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th March 2010, 05:30 PM   #115
http://homepage.mac.com/planet10/CSS...ata-080909.pdf
dave
Thanks! Good info.
What would you say the efficiency is of the speaker overall? Calculations, measurements, or guesstimates - doesn't matter.
Old 4th March 2010, 06:01 PM   #116
frugal-phile(tm)
planet10's Avatar
Efficiency is going to be whatever the driver is midband, assuming one has no need for any BSC. So ~86 dB. Sensitivity (given a voltage mode amp) will be 3 dB more.
dave
Old 22nd April 2010, 01:32 AM   #117
Jesbull is offline Jesbull  Canada
Something like the attached is what we did....
dave
I understand that the driver need to set on the brace but not too much... If by mistake I oversanded the brace, what do you propose to fill in the gap?
Thanks,
Old 22nd April 2010, 01:44 AM   #118
frugal-phile(tm)
planet10's Avatar
Depends how much gap... a thickness of paper (or a few), or some non-corrigated cardboard. In the case where we are trying to accomodate 2 different drivers, a small block of wood for the driver with the shalloest depth.
dave
Old 9th May 2010, 03:01 AM   #119
Dave. I know that I am getting off the main subject of these posts, but can't think where else to pose this question :- What is a reasonable alternative to ply for enclosure building? Where I live, decent ply is EXPENSIVE . It costs about four times what particle board costs, which really makes me think twice about trying some of the designs for the CSS EL70's. I accept that particle board is inferior to ply (MDF seems to be even less acceptable), but if the big difference in material cost means not making anything, then that is a shame. There must be many of us who are frightened off by ply costs, so what could we use in lieu? Double thickness of half inch particle board? 18mm particle board face on one side with three ply? Maybe Scottmoose could add his views?
Robert
Old 9th May 2010, 04:42 AM   #120
frugal-phile(tm)
planet10's Avatar
MDF or partical board speakers are better than no speakers at all. Many people are ignoring the recommendation for ply and using MDF and are still enjoying their loudpeakers.
The alternatives to ply are all essentially, make your own ply.
6mm particle board + 6 mm HDF laminated inside and out with plastic laminate
6 layers of 1/8" MDF
particle board laminated inside & out with a layer of fiberglass mat.
that sort of thing. The plywood is probably "cheap" in comparison
dave
Offset Bipolar MLTL with CSS EL70 Drivers--Part 1 Jim Griffin Full Range 48 18th October 2012 04:24 AM
Introducing The new CSS EL70 CSS/XBL CSS 41 19th April 2010 09:23 PM
Bipolar electrolytics dsavitsk Parts 3 8th January 2006 10:48 PM
How does this bipolar look? punchpeanut Solid State 11 2nd October 2003 07:48 AM
Copyright ©1999-2013 diyAudio
