Old 29th July 2009, 01:37 PM   #1
Tripmaster's Avatar
Default Brines FT-1600 Mk2 Build
Hi there
I have almost finished building a pair of Bob’s FT-1600 Mk2 speakers. In preparation I decided to wire up an inductor and a resistor to one of my FE167E drive units.
When I turn on the amp the cone slowly moves back and holds its position, then plays music. When I turn the amp off the cone returns to its normal position. Is this ok, or is it an indication the driver is wired out of phase?
Here is a sketch of the wiring…
Richard
Old 29th July 2009, 02:56 PM   #2
vitalstates's Avatar
Hi Richard
looks like there might be some dc on the output. If you have a dmm you could set it on low dc volts and measure whats across the speaker terminals at idle. if possible measure both both speakers and report back.
its best not to have any dc on your amp output, but sometimes it can be found in small amounts.
Ed
Old 29th July 2009, 02:58 PM   #3
Bob Brines's Avatar
You have wired the BSC filter correctly. What I suspect is that your amplifier is putting out a DC offset. Try another amplifier and report back.
Bob
Old 29th July 2009, 03:00 PM   #4
Tripmaster's Avatar
Originally posted by vitalstates
Hi Richard
Ed
Hi
I measured for dc offset a little while a go and only had about 50mv per channel. I'll check again!
Richard
Old 29th July 2009, 03:14 PM   #5
Tripmaster's Avatar
OK, here are the readings
Right Channel
- Power on peaks for a split second at 194mV
- Idles at 15mV
- Power off peaks for a split second at 122mV
Left Channel
- Power on peaks for a split second at 189mV
- Idles at 19mV
The amp has no source or speakers connected.
Richard
Old 29th July 2009, 06:56 PM   #6
Richard
ideally need to measure with a load, i.e with speakers connected, or better with a power resistor if the amp is suspect.........
anyway, it looks like you have some dc on the output, which is not the best way to go......I think I would try another amp as Bob suggests.
Ed
Old 29th July 2009, 07:25 PM   #7
Tripmaster's Avatar
Ed
Hi Ed
Duh, I forgot about that! I suppose I could use one of the 6ohm speaker resistors between positive and ground for each channel.
I have connected an 8ohm speaker to each channel and here are the readings again.
Right Channel
- Power on peaks for a split second at 128mV
- Idles at 14.6mV
- Power off peaks for a split second at 133mV*
Left Channel
- Power on peaks for a split second at 40mV
- Idles at 20mV
- Power off peaks for a split second at 120mV
I like your amp reviews on your website BTW.
Richard
Old 29th July 2009, 07:31 PM   #8
Tripmaster's Avatar
Hi Bob
Is there a reason for using silicon sealant to fix the supra baffle to cabinet, rather than the flexible adhesive used to attach the cement board? And do you avoid applying Danish oil to the veneer behind the s.baffle?
Richard
Old 30th July 2009, 12:24 AM   #9
Bob Brines's Avatar
Hi Bob
If you use Liquid Nails to attach the supra baffle to the baffle and it oozes out onto the baffle, you will find it next to impossible to get the NL off of the baffle without screwing up the finish. If you use clear silicon seal, you can correct the error with no damage. Really, just a safety measure. One of those little 6" tubes should be enough.
Finish the entire baffle. The silicone seal sticks to the finish just fine.
Bob
Old 30th July 2009, 09:47 AM   #10
Tripmaster's Avatar
Hello
I have three amps, an Incatech Claymore, Alchemist Kraken and a dual mono LM3886 chipamp.
The figures supplied so far are from the Kraken, but the Claymore also has readings within similar range. Are the start-up and power down readings a problem bearing in mind the voltage only peaks for a split second?
Richard
Brines FB-20 done!!!! Finally steviedon Full Range 16 13th June 2009 01:37 AM
Parasound DAC-1600 R-K Rønningstad Digital Source 18 14th October 2008 07:14 PM
technics sl-1600 kazoo Analogue Source 2 11th August 2005 01:10 PM
Page generated in 0.11730 seconds (76.53% PHP - 23.47% MySQL) with 11 queries
