Brines FT-1600 Mk2 Build
Old 12th November 2009, 01:50 PM   #71
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Originally Posted by gychang View Post
any chance for pictorial on how u built these?
gychang
Hi
I am currently putting together an audio projects website and I will be featuring my Brines speakers.
I don't have the pictures to hand at the moment but I will post a message on this thread when its up and running.
I hope this helps.
Old 7th August 2010, 06:59 PM   #72
Tripmaster's Avatar
Hi
I am thinking about adding a super tweeter to my speakers but would like to know if you have any suggestions for an enclosure?
Bob has recommended the FT17H. I would like to mount them in a small case on top of the existing speakers if possible.
http://www.fostexinternational.com/d.../pdf/ft17h.pdf
I don't necessarily need to use the FT17H you have better suggestion.
My speakers
Old 7th August 2010, 09:15 PM   #73
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Well, they don't need an enclosure, so you can make a simple box with the same finish as the main enclosure to stick on the top. The FT17 is a nice little unit, good as anything else you'll get for the price & works well with the 167.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 7th August 2010, 09:20 PM   #74
Tripmaster's Avatar
Thanks Scott
What would you recommend crossing the tweeter with?
Old 7th August 2010, 09:24 PM   #75
Scottmoose's Avatar
That's one of those 'how long is a piece of string' questions TBH. Depends on what you happen to like; I'd probably cap it off at ~12KHz initially & adjust from there. It shouldn't need any padding, IIRC Bob took some measures a while back & found its sensitivity to be pretty much identical to the 167.
Old 7th August 2010, 09:34 PM   #76
Tripmaster's Avatar
Scott...what value cap would achieve ~12Khz?
Old 7th August 2010, 09:45 PM   #77
Scottmoose's Avatar
Try ~1.5uF. Just get a handful of cheap caps. & see which suits you best. Once you've done that, you can buy something fancier of the appropriate value if you feel the need.
Old 7th August 2010, 09:48 PM   #78
Tripmaster's Avatar
Thanks Scott, that's good advice.
Brines FT-1600 Mk2 BuildHide this!Advertise here!
Parasound DAC-1600 R-K Rønningstad Digital Source 21 12th November 2014 12:28 PM
Brines FB-20 done!!!! Finally steviedon Full Range 16 13th June 2009 01:37 AM
technics sl-1600 kazoo Analogue Source 2 11th August 2005 01:10 PM
