Brines FT-1600 Mk2 Build
Old 11th August 2009, 08:08 AM   #51
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Those look very nice!
Old 11th August 2009, 08:13 AM   #52
Tripmaster's Avatar
Hi Bob
I've just stuck the supra baffles with silicone. How long do you wait before mounting the drivers.
I had a bit of a set back due to dust falling on to the wet paint, so annoying!! But after a light sanding and respray they look fine
Richard
Old 11th August 2009, 09:55 AM   #53
Tripmaster's Avatar
Last question, I hope!
Bob suggested inserting a stiff cardboard tube into the port before committing to the standard 4” plastic tube.
How does the length of the tube effect the sound?
Richard
Old 11th August 2009, 03:09 PM   #54
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The longer the port the lower the tuning
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th August 2009, 04:03 PM   #55
Tripmaster's Avatar
Thanks Dave
The speakers are complete! but the silicone manufacturer says the sealant will take 24 hours for 1.5mm of silicone to dry. He also said the silicone might not adhere to the supra baffles because the MDF isn't primed...argh!!
Oh well, I better not stand the speakers up until tomorrow morning
Richard
Old 11th August 2009, 04:39 PM   #56
chrisb is offline chrisb
Originally posted by chuyler1
What products did you use to finish those? They look great.
On the little red boxes, the veneer was paper back quarter cut white oak, stain was industrial alcohol based dark pigmented named "Port Mahogany".
On the micro-towers, the veneer was paper backed cherry, stain was ML Campbell Woodsong WS26124 Cinnamon.
On both, the top coat was ML Campbell Magnamax pre catalyzed Nitro cellulose lacquer (25 degree sheen, 4 coats, hand sanded between)
The cherry's pores are quite easily filled by the 3rd or 4th coat, the oak still retains much of the pore texture. One client had requested oak grain to be fully filled with water based polyurethane - it took at least 6 spray coats and looked like cheap plastic laminate.
Even if your layup skills are up to the challenge of working with contact cements, avoid solvent based adhesives on paper or wood backed veneers when the product will be finished with solvent based stains or top coats.
like my mind, this space intentionally blank
Old 12th August 2009, 05:03 PM   #57
Tripmaster's Avatar
The day that I have been waiting for, and I'm far from disappointed!
The speakers actually sounded surprisingly good from the start (not as thin, boxy and screechy as I was expecting) and and over the last four to five hours the bass has developed significantly. I've tried a variety of music and it sounds good with most easy going genres.
I really must thank Bob, you've been a great help and I thoroughly recommend your speaker instructions, very clear and easy to follow.
If you are looking for a relativity simple build, not too large and something the wife would like, it should defiantly be on your short list!
I've taken lots of photos during the build and if anyone is interested I'll be happy to upload them.
I'll post further information as the drivers break-in.
Richard
Old 12th August 2009, 05:06 PM   #58
Tripmaster's Avatar
Originally posted by vitalstates
what about the cones?, do the cones move with the chipamp at startup?
The cone movement was due to a slightly high dc offset during powering on and off...all is well with the chipamp.
Old 12th August 2009, 05:18 PM   #59
Puffin is offline Puffin  United Kingdom
Superb finish there trippy. Give yourself a shandy
Old 12th August 2009, 05:19 PM   #60
chuyler1 is offline chuyler1  United States
chuyler1's Avatar
Is the port supposed to be pulled out like that? It looks like it is pulled out of the hole like 1/2".
Brines FT-1600 Mk2 BuildHide this!Advertise here!
Parasound DAC-1600 R-K Rønningstad Digital Source 21 12th November 2014 12:28 PM
Brines FB-20 done!!!! Finally steviedon Full Range 16 13th June 2009 01:37 AM
technics sl-1600 kazoo Analogue Source 2 11th August 2005 01:10 PM
