Brines FT-1600 Mk2 Build
Old 31st July 2009, 09:43 PM   #21
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Originally posted by Puffin
It was only a matter of time!
Old 31st July 2009, 09:51 PM   #22
Tripmaster's Avatar
Hi
I haven't had time to test the amp with the drive units, I should have said. My speakers are a week or two from completion and as the speaker wiring is OK I'll wait until then before retesting.
Do you have an ad in hi-fi news this month?
I'll post a few pictures of the build when I have a moment
Richard
Old 1st August 2009, 09:58 PM   #23
Tripmaster's Avatar
Hi
Here are a couple of photos of the cabinets before I apply the the oil.
Bob, sorry to cover old ground. Do you apply a wax after the four coats of oil? I was planing to do this but I just wanted to check the silicon would stick to a wax coating.
I have to say I beginning to get quite excited!
Thanks for the help so far
Richard
Old 2nd August 2009, 12:57 PM   #24
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Originally posted by Tripmaster
.... Do you apply a wax after the four coats of oil? I was planing to do this but I just wanted to check the silicon would stick to a wax coating.
Looking good!
You may wax if you choose, but wait a couple of weeks for the oil finish to completely set.
Bob
Old 2nd August 2009, 08:32 PM   #25
Tripmaster's Avatar
Originally posted by Bob Brines
Looking good!
Bob
Thanks Bob
Old 8th August 2009, 06:20 PM   #26
Puffin is offline Puffin  United Kingdom
Six days ago.....
Old 8th August 2009, 06:31 PM   #27
Tripmaster's Avatar
Hi
Richard
Patience dear boy...it's not quite two weeks!
I am going to stick the Supra baffles on tomorrow and install the drivers on Monday (wife's away!)....so it should be Tuesday latest!
Richard
Old 8th August 2009, 06:39 PM   #28
Tripmaster's Avatar
Hi Bob
This is a really daft question....(so why ask it!)
Would you recommend untwisting the single pair cat5 cable connecting the drivers to the terminals?
I have two children and I think it might be a good idea to fit a grill to the driver. You mention the following grill on your website...
'This is the easiest sollution. No modifications are required to the basic speaker cabinet. The grill is screwed to the cabinet through the driver mounting holes. If you would like to remove the grills at a later time, simply unscrew the grills and replace the screws in the driver mounting holes. This cannot be done on a regular basic. You should consider the grills permanent. A charge of $50 will cover my costs of installing the Fostex factory grills.'
Is this something you sell on its own, or could you briefly explain how its made?
Richard
Old 8th August 2009, 06:40 PM   #29
Goodee!
Old 8th August 2009, 10:41 PM   #30
Bob Brines's Avatar
Hi Bob
You can do it either way. Separating the wires increases inductance, twisting them increases capacitance. Since inductance may roll off the high end, I would think that twisted is preferred. Try it both ways and report back.
Buy them from Madisound. Hint: get 1/4" diameter magnets and press them into the mounting holes of the grills. The grills will then stick to the driver mounting screws.
Bob
Brines FT-1600 Mk2 BuildHide this!Advertise here!
Parasound DAC-1600 R-K Rønningstad Digital Source 21 12th November 2014 12:28 PM
Brines FB-20 done!!!! Finally steviedon Full Range 16 13th June 2009 01:37 AM
technics sl-1600 kazoo Analogue Source 2 11th August 2005 01:10 PM
