frugal-phile(tm)
After seeing & touching the PE curved Parts Express cabinets we thot we'd explore the idea of a flat-pak baffle assembly that turned the 1/2 ft^3 (14 litre) PE cabinet into a member of the Fonken family.
The PE cabinet is quite good. Top, bottom, & back are all quite small. Sides are a plywood made of a laminate of 6 layers of MDF. Sides, top & bottom are braced. The weak point is the MDF baffle. They are well finished and come in a variety of flavours (black, cherry, maple). The one down-side is that the MDF is somewhat "soft" and it is not all that hard to damage the edges (pictures later). We devised and built up a baffle & installed them into a set of cherry finished PE cabinets. The Success: they work really well. Not quite the finese of a set of FonkenPrime but close. The Failure: turns out it is almost as hard to build these as it is to build a full set of FonkenPrime. Also a problem was the dimensional consistancy of the 2 pair of PE cabs we have was not all that good. So we had to abandon the idea of flat-pak baffles. The Upside: someone can have the R&D mules REALLY cheap (see the Swap Meet) Full plans are here http://homepage.mac.com/tlinespeaker...map-290709.pdf (not there as i write this, i need to run them thru acrobat) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
frugal-phile(tm)
another
#7 | |
They look good, Dave!
Cheers! |
#8 |
frugal-phile(tm)
Sorry for the delay... i finally got the plans in place so thatthe link in post 1 works.
dave
#9 |
Very interesting.
I have to admit, I prefer the look of your FonkenPrime though. You didn't mention any disadvantage from not having the bevelled edges compared with the FonkenPrime ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#10 | |
frugal-phile(tm)
dave
| rFonken R & D mules with FE127eN | planet10 | Planet 10 hifi | 3 | 5th April 2011 08:58 AM |
| First Re-Cap Success ! ! | 65blkbkgt | Car Audio | 9 | 11th July 2007 07:47 AM |
| wow! ladegaard success. | graeme uk | Analogue Source | 25 | 22nd January 2007 06:01 PM |
| Page generated in 0.09888 seconds (78.86% PHP - 21.14% MySQL) with 11 queries |
