Old 15th July 2009, 02:05 PM   #1
Banned
Question Why not a ribbon tweeter instead of a horn tweeter?
I was thinking about adding the Fostex T90A to my Sachiko/Fostex 208 Sigma build, but now I am rethinking that to use a ribbon tweeter instead. I really can not see a down side to this, but maybe I am overlooking something. If I am please inform me before I start this build :-)
The Fountek NeoCd2.0M, a 5" ribbon tweeter which is 98 db efficient. This should be fine with minimal need to damp the tweeter to match the Sigma 208. What do you all think about this?
Old 15th July 2009, 02:10 PM   #2
JC951t is offline JC951t  Taiwan
Looks like we're searching for the same answer.
I like the sound of ribbons but the set back that
I've notice is low dispersion characteristics.
Old 15th July 2009, 02:14 PM   #3
Banned
The dispersion aspect does not bother me. I have owned ribbon speakers in the past and do not mind a sweet spot to deal with. I am usually always seated when I am seriously listening anyway :-)
Old 15th July 2009, 04:12 PM   #4
Hi Micheal,
I know what you mean. Yes aside from horn tweeters which I have no experience, ribbons sounds the most realistic to me.
Always very sweet & clear without sounding hi-fi. Considering
the Fountek's surface area, the sound could be overpowering
when used in conjuntion with your Sigma's. Might drown out the
lows.
Old 15th July 2009, 04:23 PM   #5
Banned
Default I don't think that will be an issue with drowning out the lows.
I will be crossing over at a very high frequency (approx. 10K) so I do not feel that will be an issue. The extra surface area will hopely just lower the distortion.
Old 15th July 2009, 04:36 PM   #6
planet10's Avatar
Ribbons are often used (Basszilla for instance).
The downside of a ribbon is that its dispersion is wider than a typical horn, so there is more of a dispersion flare at the XO.
That said when i use a supertweeter on my FonkenPrimes, half the time it is a set of CSS Ribbons (Aurum Cantus) or a set of Foster horns.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th July 2009, 04:36 PM   #7
Hi Micheal,
I'm looking at crossing over at 8-10k too but am notsure
if this range is correct as I'm building my first wide range
2 way speaker. Any advice ?
Old 15th July 2009, 04:37 PM   #8
planet10's Avatar
Default Re: I don't think that will be an issue with drowning out the lows.
For use as a supertweeter a shorter ribbon will be better.
dave
Old 15th July 2009, 04:40 PM   #9
Banned
Default Why is that Dave?
What does the shorter ribbon gain you? The frequency length does get shorter as frequency increases, but is it really that important at these frequencies?
Old 15th July 2009, 05:09 PM   #10
planet10's Avatar
The taller the ribbon, the poorer the vertical dispersion, a uniform dispersion will have a better match to the FR. Also a longer ribbon is usually a trade-off between HF for LF to enable a lower XO.
dave
Horn loaded ribbon tweeter Mikael Abdellah Multi-Way 22 5th June 2011 08:58 AM
Horn or Ribbon tweeter with fullrange sharptouch Full Range 1 12th August 2008 05:01 AM
Horn-loading Ribbon Tweeter? mefistofelez Multi-Way 17 9th November 2004 08:58 PM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 08:21 PM
Page generated in 0.11805 seconds (76.12% PHP - 23.88% MySQL) with 10 queries
