New Box Idea (Life after BIB's)
Old 15th July 2009, 05:57 AM   #11
rjbond3rd is offline rjbond3rd
Oops, I stand corrected -- apparently HornResp can model MLTL's. My apologies:
http://www.diyaudio.com/forums/showt...50#post1854550
Old 15th July 2009, 06:31 PM   #12
Godzilla is offline Godzilla  United States
Godzilla's Avatar
http://homepage.mac.com/tlinespeaker...7-MLV-0v99.gif
The Meliva was the box i was thinking of... has one been developed for the Fostex 165/6/7/8? LOL
>>> symmetrical ports above and below the driver
If you like ports on top and bottom maybe you can re jigger and create a one off Meliva style box.
Old 15th July 2009, 08:39 PM   #13
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Come on Jeff... 1st spelling, Mileva, 2nd, it is for the FE127. Demetri is for FE207e (FE167 can be used, but Fonken167 is better for that driver.
How are FF165KeN auditions going?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th July 2009, 09:28 PM   #14
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
To my very untrained eye, Horn Response seems to factor in some quarter wave action, but not nearly to the extent that MJK's sheets do. It is more than likely that I don't know what I'm doing though.
Jeff, I'm also considering doing an OB setup similar to the Betsy +Boomer. I've got plenty of amplification, so I'd probably use a cheap proaudio crossover (for the woofers) driven by a voltage divider on the outputs of my main amp.
FWIW, the folding scheme I drew is an expanding pipe (like a BIB or voigt) that is folded one time less than the folding in the Demetri or Mileva. Going vertical makes it tough to get as much length as the Demetri if you shoot for a reasonable driver and overall height. I was actually pondering a BIB folding scheme when it occurred to me, so don't think I was trying to copy Dave's (or Scott's) work. However, their work does lead me to think that the folding scheme would work.
pj
Old 15th July 2009, 09:31 PM   #15
Originally posted by pjanda1 I'm having a hard time getting an MLTL to sim any different from a vented box with the same Vb and port.
Hi PJ, are you doing it this way (from page 16 of HornResp's Help): "To model a mass-loaded horn specify the mouth cover plate as a conical segment having negative flare (mouth area < throat are) and a length of 0.01 cm, and the mouth mass-loading port tube as a cylindrical exponential segment having zero flare (mouth area = throat area)."
Old 15th July 2009, 10:45 PM   #16
(Oops, sorry PJ, you posted while I was composing my post, so please disregard my post...)
Old 16th July 2009, 02:12 AM   #17
frugal-phile(tm)
planet10's Avatar
Demetri is folded once, so one less fold would be no folds
Your drawing of post 4 differs only in bifurcating the last half of the line instead of the 1st half.
dave
Old 16th July 2009, 04:34 AM   #18
pjanda1's Avatar
Yup.
dave
I miswrote. Technically, both the first and second half of the line in my drawing is bifurcated as compared to a straight expanding line. And not only are the bifurcated, but separated, whereas the second half of the Demetri is bifurcated but could easily not be with the removal of the divider. But when were semantics important in speaker design?
Right now I'm actually giving more thought to a straight MLTL made of Sonotube. I'll have to see if my new environs harbor decent lengths of big diameter cardboard tubes.
pj
Old 16th July 2009, 05:34 AM   #19
frugal-phile(tm)
planet10's Avatar
The brace could be holey, i figured since the line was tapered it really didn't neeed to be.
dave
Old 16th July 2009, 05:20 PM   #20
GM is offline GM  United States
GM's Avatar
Default Re: New Box Idea (Life after BIB's)
Greets!
FWIW, I did a number of designs awhile back to see what's what and this TQWT with a ~30" wide baffle was my preferred near wall choice, so will theoretically meet your goals also. I prefer higher driver placements, but dropping it down to 36" shouldn't audibly affect performance once stuffed to suit. MathCad sim is 0.25 lbs/ft^3 polyfil evenly distributed along its length to mimic my normal layers of 1" acoustic fiberglass insulation at the top combined with lining one of any other parallel walls.
GM
Edit: Due to the wide baffles, the drivers should be mirror imaged with golden or acoustic ratio offsets.
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
New Box Idea (Life after BIB's)Hide this!Advertise here!
for the life of me CarlyBoy Tubes / Valves 5 30th January 2008 10:06 AM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 09:18 AM
The DIY Life DJ Exprice Everything Else 11 25th December 2006 07:38 PM
Another A-75 comes to life BobEllis Pass Labs 13 18th February 2004 01:00 AM
Copyright ©1999-2017 diyAudio
