Old 9th July 2009, 12:51 AM   #1
chuyler1's Avatar
Default Experimenting with Stuffing
Inspired by Denis' thread about his Little Big Horn I decided to experiment with some stuffing in my frugelhorns. Here are the results.
Graph1: Near field response taken at the driver and at the mouth for reference
Graph2: Difference at mouth caused by a small handful of pillow stuffing placed up the mouth.
Graph3: Difference at listening position
Overall listening impressions. The bass sounds a little tighter but less dominating. If anything I would say it is less hollow sounding. The graph shows less than 1db difference below 80Hz but a 6db difference at 127Hz. I'd call that a success as I've always wondered why the 120-250 range was so peaky.
Any thoughts on what else I should try?
Old 9th July 2009, 05:22 AM   #2
The horns are peaky in that range because certain compromises had to be made to make such a low response in a limited size package.
I pulled my frugal horns back out of the closet recently and I've been using them exclusively. I was planning on doing exactly what you are doing now but haven't got to it yet.
For now, the cure I'm implementing is mating them to an OB woofer w/ a high crossover point. The frugal horns are currently high passed at 230 hz, 42 db/oct slope and no further signal processing except the "loud" button on the (cheap) amp activated to plump up what's left of the midbass and sweeten up the highs. This high crossover point essentially cuts out the horn action completely, so the box is currently doing little more than holding up the driver. Regardless, above 230 hz, these little things are stunning.
I'm glad to see your measurements of stuffing applied to the mouth (saves me the work of doing my own experimenting). You can also try some stuffing in the throat, but you should probably tack it in so it doesn't get lost in there forever. Take care to not completely block the throat.
Before I put these speakers in storage a few months ago, the last thing I tried was opening up the full potential area for the back chamber. It did reduce the peaks noticably but not enough, and it's not something I would recommend - unless you plan to go further yet - since IIRC the larger chamber will negatively affect excursion, which is already taxed enough, being a 4 inch driver.
By going further, what I mean is that I plan to experiment with small 1/4 wave resonators in the back chamber. This concept has been discussed recently in the subwoofer forum, and consists of installing 1 or more thin empty tubes (open on one end, closed on the other). Length is determined by 1/4 wavelength of the frequency you wish to notch out - in my case the one at ~220 hz bothers me much more than the one an octave lower - so IIRC the length would be ~17 inches. The diameter is determined by whatever will fit in there and get around the bend, so maybe some type of (unkinked) hose or bendable pipe with an elbow, capped on one end and with the open end near the driver. That should seriously impact the strength of the higher of the peaks (imo the one that can make the frugal horn sound hollow and boxy). The back chamber will still be unusually large even with the resonators in place, so a bit of back fill may be desired. Anyway, I only mention this in case you felt like trying it and evaluating it and measuring it and posting the measurements. If this works it should be a much better option than stuffing, since as you found out, stuffing does not attack peaks specifically, it pulls down the whole bass range.
I'm determined to make these work if at all possible without a high xo point, but I'm doubly challenged since I have severe room modes that correspond almost exactly the the horn's peaks.
Old 9th July 2009, 03:26 PM   #3
chuyler1's Avatar
Hmm, that is an interesting idea. So length is the only thing that matters? Not volume or diameter? 17" would be tough to fit in but it could be done. Do you have any links to discussions about this approach?
After some more listening last night and this morning I have decided to keep the stuffing in. It allows me to turn it up louder without the 'boominess' taking over.
Old 9th July 2009, 05:37 PM   #4
I'm no expert on this subject but AFAIK the concept is very similar to a helmholtz resonator bass trap - in the way that a ported box is similar to a transmission line.
If we were using a helmholtz trap the volume of enclosed space along with the size and length of the opening (port) would be incredibly important. Technically, you might be able to just add a port to the enclosed space inside the horn and tune it to the desired notch frequency by lengthening or shortening the port. I'm pretty sure something like that should work, but other than selecting the notch frequency there's nothing more that can be adjusted.
OTOH, a 1/4 wave resonator is different than a helmholtz resonator in that the length (and shape - which we can disregard since it's a uniform csa) determines the tuning. These are tuned in the same manner, adding or reducing length to obtain the desired notch frequency tuning. These (in my mind) are more flexible, in that I'm imagining a 1 inch diameter hose length (capped on one end). If the one hose isn't enough, add another, and another, until the notch is big enough.
The q of the notch (sharp deep notch vs shallow wide notch) can be adjusted in both a helmholtz and 1/4 wave resonator by playing with stuffing.
PLEASE note that I have no experience with this type of mechanical notch to date, but most recently it has been discussed somewhere in the tapped horn thread as a result of it's use in a commercial product, so I'm assuming the concept works well when needed.
Old 9th July 2009, 06:41 PM   #5
chuyler1's Avatar
So does the volume of the inside of the hose or whatever act as part of the CC? As you make the hose longer, it must have other effects on the output right?
Old 9th July 2009, 08:05 PM   #6
GM is offline GM  United States
GM's Avatar
You're interested in one or more band stop filters and yes, they reduce the filter (rear) chamber's net Vb if you don't locate them somewhere else with a duct back to it like I've seen done on some Lowther horns: http://paws.kettering.edu/~drussell/...ers-Frame.html
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th July 2009, 06:38 PM   #7
Thanks for another great link sir.
Old 10th July 2009, 07:00 PM   #8
GM's Avatar
Old 13th July 2009, 06:21 PM   #9
chuyler1's Avatar
GM
The diagrams remind me alot of how auto manufacturers design their intake systems. Everyone rips them off to install straight pipe cold-air-intakes but quite a bit of R&D goes into those labrinths of plastic to reduce engine noise.
Edit: Doh, how about I read the introduction before i open my mouth.
Anyway, I've been giving this some thought. I'm not sure I want to make any more changes to my frugels, but I'd be interested in experimenting with the concept on a future design.
For example, how about attaching some 1/2"x1/2" square rods to the front of a design like the frugel, separated by 1/2" and then placing a new baffle over them, creating channels that run the height of the enclosure. Then you can insert more 1/2"x1/2" square rods into the bottom to adjust the length of the channels until the desired freq response is achieved. Cut off the extra that sticks out the bottom and glue in place.
Do you follow or should I draw a crude picture with mspaint?
Old 13th July 2009, 06:43 PM   #10
GM's Avatar
Originally posted by chuyler1
.........but quite a bit of R&D goes into those labrinths of plastic to reduce engine noise.
And to make the motor more efficient. Racing was my primary hobby, so learned TL, horn, etc. design primarily to design high performance intake/exhaust systems.
Square rods or square tubes? Best to draw a picture, I guess.
GM
Experimenting with Chipamp.com Mono PCBs Tripmaster Chip Amps 24 14th February 2009 01:20 PM
Experimenting ... Volt Stage Hybridically lineup Solid State 12 26th June 2007 11:00 PM
Really cheap player for tweaking and experimenting. Zero One Digital Source 0 20th August 2006 02:27 PM
Page generated in 0.12232 seconds (84.49% PHP - 15.51% MySQL) with 11 queries
