Old 1st July 2009, 04:32 PM   #1
Default passive radiator for 40-1197?
suppose you have a pair of Fostex 103's or RS 40-1197s
you are supposed to put these in a horn loaded enclosure
or a bass reflex design, correct?
What about a 16" X 6" X 8" box with a small passive radiator?
Madisound has a 5 1/4 in Passive for 15$ each
any comments?...thanks
Old 2nd July 2009, 03:08 AM   #2
GM is offline GM  United States
GM's Avatar
Well, if I had to 'suppose', I'd suppose it should be in a small sealed cab like originally intended several decades ago (at least that's my dim memory), but it's rarely used that way these days.
Anyway, per Tom Danley we want a PR that has ~1.5 - 2x the displacement as the 1197, so at nearly 2x, this PR is plenty big enough, but this box alignment only needs a ~4.4 g Mms, so at 48 grams, it's way too heavy. This PR requires an equivalent vent length of nearly 180".
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 4th July 2009, 04:10 PM   #3
TerryO is online now TerryO  United States
TerryO's Avatar
GM
GM, With a vent that long it's almost possible for you to listen to his speaker at your house in Georgia, if the vent was external.
My pair of Hi-Tweek Black Box Nearfield Monitors use Modified RS 40-1197 drivers in a vented box that is tuned to 65 Hz. However, they are very purpose specific and I wouldn't recommend it for normal use. They were intended for nearfield use and can sound congested (constipated?) at levels necessary to fill a moderately large or even a normal sized room.
Tuned higher, they can certainly be used in a vented or BLH solution.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 5th July 2009, 03:40 AM   #4
GM's Avatar
Greets!
Yeah, with a ~18.8 Hz 1/4 WL it would carry a long way.
Yeah, little drivers and big rooms don't match up too well, though I was surprised at how well the little folded, bottom vented ML-Voigt horns I made for Dave's tweaked 1197s filled a fairly large, though reflective, hotel conference room semi-full of folks at one of the Atlanta DIY Meets. IIRC they were tuned in the 60s and driven with a restored Marantz tube integrated map? receiver? through either an 8 or 10 ohm series resistor. Memory's pretty much MIA these days.
They were very lush sounding, handling a variety music from Alison Kraus to Dave Brubeck with equal aplomb. Dave's coating and phase plug and ? really smoothed them out. Anyway, this is the cab: http://www.planet10-hifi.com/boxes-fostex.html#GM-mlv
Happy 4th and all that jive!
GM
Passive radiator Chris8sirhC Subwoofers 4 5th August 2008 05:49 PM
Passive radiator jamikl Subwoofers 1 3rd June 2006 09:23 AM
Passive Radiator Fazorcat Subwoofers 42 10th May 2006 07:05 PM
Passive Radiator For ESS qdoc Multi-Way 0 8th July 2004 05:06 AM
Page generated in 0.07534 seconds (84.46% PHP - 15.54% MySQL) with 11 queries
