Hello to all speaker builders.
First of all, I would like to introduce myself. Coming from croatia, built a couple of twoo way speakers following projects from the net. My last project is monacor sp200x in app. 50 liter box tuned to 40 Hz. Since I do not know much about crossovers, zobel, notch filter, would appreciate if someone help me what do I need to linearize response of monacors in this box because mids are pesky and flagrant. Here's a pic. |
#2 |
You might want to use something like this as a guide / starting point http://www.troelsgravesen.dk/SP200.htm
#3 |
Thanks for your answer, already have read this project even before I bought the drivers.
But I wanted to keep it simple because I thought it would be more opened and linear, considernig the potentiality of driver to the 12-15 k, but this sentence confused me: ".... It's possible to add a series notch filter to smooth the response in the treble region and 0.82 mH\\2.5 uF\\10 ohms (all in parallel) make a nice and smooth response from 1-10 kHz..." I must confess that I'm really new in this domain, so would this notch filter resolve awful mids and higher bass 'cause vocals are tearing my ears. I |
#4 |
There's only so much you can do with a cheap driver, but yes, that should help, although depending on your tweeter you'll probably have to rework it's XO to match.
#5 |
why don't you try removing the whizzer cone as Troels suggests in his build and add a phase plug..
#6 | |
-Micha |
#7 |
http://www.cinetson.org/phpBB3/haut-...nde-t8512.html
they filtered with 1.2 mH + 12 Ohm + 3 uF and added (glue) a SPM90 in opposite phase, seems to add some energy in the highs... http://www.monacor.de/typo3/index.ph...ukatid=&brand= |
#8 |
I put 0.82mH/10Ù/2.7µF as a serial notch filter, and the beam in mids disappeared...just as it was said in the above link, "..smooth response from 1-10 kHz...".
Thanks to all people who tried to help... |
| What about Monacor? | mr_push_pull | Multi-Way | 8 | 17th October 2010 10:41 PM |
| need tips for monacor sp200x | tyor | Full Range | 11 | 28th December 2007 01:48 PM |
| monacor | goran14 | Multi-Way | 2 | 20th April 2005 02:12 PM |
| Monacor | Vedo | Multi-Way | 2 | 10th February 2005 09:31 PM |
| Page generated in 0.08554 seconds (76.73% PHP - 23.27% MySQL) with 11 queries |
