#21 |
Bob Reimer at CSS (Creative Sound Solutions -Vancouver) will receive a shipment later next week. Selling price is likely to be around $200 USD per driver. Re the Xmax, I've more up to date info. The 1 way = 9.0-mm. The 12-mm total was given originally for guys who wanted to run the Alp12 as a woofer, my recommendation being 6-mm for 1 way at near constant high loads. If you're planning to use full range then work on 9-mm. Take a look page 3 of the Alp12 in the Markaudio section. There's some interesting details on this driver's suspension: Mark's new Alpair 12 Cheers, Mark. |
#22 |
These drivers look pretty dam sexy.
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#23 |
Hi Guys,
Bringing you up to date, the T/S shown on the first page of this thread was from measured from the Pre-production sample, aimed for horn use. A number of DIYer's contacted me about producing a version suitable for a larger choice of box designs. I wanted to produce 2 versions (horn) and (wide use). Sadly, the economic situation has made this a non-starter. So the production version has been tweaked (thanks to help from Matsubara san) to make it more suitable for a variety of box concepts. Here's the T/S Mass Production data. Revc= 7.000 Ohm Fo= 46 Hz Sd= 143.14 Cm Vas= 22 Ltr Cms= 0.750 MM/N Mmd= 14.886 g Mms= 15.871 g BL= 8.752 T.M Qms= 1.454 Qes= 0.420 Qts= 0.327 Levc= 0.058m H No= 0.493 % SPLo= 89.3 dB X Max= 9.0-mm 1 way Pwr cont= 50 watts Apologies for any confusion. More can be read on the Markaudio thread: Mark's new Alpair 12 Cheers, Mark.
#24 |
Hi Guys,
New cabinet design for the Alpair 12. Here's the link for a simple to build - Damped Air Coupler design. The new thread will feature the build and tuning process. Alpair 12 - Damped Air Coupler box design Thanks Mar. |
| Alpair 7 - out of the bag | markaudio | Full Range | 16 | 27th November 2009 01:30 PM |
| Alpair 10 and 5 Combination | _henry_ | Full Range | 19 | 1st June 2009 09:24 PM |
| alpair 10 box width ? | norman bates | Full Range | 9 | 15th May 2009 04:54 AM |
| Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 12:37 PM |
| Can anyone help TL or ML-TL for Alpair 10 | _henry_ | Full Range | 3 | 31st December 2008 07:31 AM |
| Page generated in 0.09511 seconds (72.58% PHP - 27.42% MySQL) with 11 queries |
