Alpair 7 - out of the bag
Old 16th June 2009, 08:44 AM   #1
markaudio is offline markaudio  Hong Kong
markaudio's Avatar
Default Alpair 7 - out of the bag
Hi Guys,
Since Mark L has "let the cat our of the bag", I've been receiving much email traffic. I'm not able to cope with the various questions and make these drivers at the same time. So here's some basic information from the pre-production units.
I will make a proper post in Vendors later next month once done making these drivers.
Alpair 7 - Extended Full Range unit operating to 30-kHz @+80dB.
New frame - Dia = 130-mm
New cone - all machine formed (not spun)
New U cap - dual bond direct on to a pre-formed edge at top of v coil.
New connector system - separate moulded units interlocked into the frame, colour coded.
T/S - Pre-Prod batch 003 - LMS-4114-06/09
ALPAIR7 - 2 mag. with cover
Revc= 3.600 Ohm
Fo= 65.835 Hz
Sd= 5.027K mm
Vas= 5.148 Ltr
Cms= 1.435m M/N
Mmd= 3.868 g
Mms= 4.073 g
BL= 2.819 T.M
Qms= 1.944
Qes= 0.763
Qts= 0.548
Levc= 19.445u H
No= 0.186 %
SPLo= 84.715 dB
Xmax = 4.5mm (1 way)
Rated at 20 watts cont.
That's it for now. Please email me only if urgent.
Mark.
Old 16th June 2009, 08:46 AM   #2
markaudio's Avatar
And a Pic
(Also, my chance to intro our Evan Yu, excellent speaker builder, worth his weight in gold!)
Old 16th June 2009, 02:13 PM   #3
ped is offline ped  United States
Very cool!
Will these afford little more spacing between the mounting holes and the edge of the driver cutout? It's a little too close for comfort with the 6's and 10's that I have
Old 16th June 2009, 02:55 PM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Mark,
It looks like the A7 has a double magnet & a cap?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th June 2009, 03:06 PM   #5
EUVL is offline EUVL  Europe
> Since Mark L has "let the cat our of the bag" .....
Maybe we should call it the "Cat" instead.
Patrick
Old 16th June 2009, 03:21 PM   #6
_henry_ is offline _henry_  Australia
ALPAIR evolution
looks great
Old 16th June 2009, 04:17 PM   #7
HareBrained is offline HareBrained  United States
HareBrained's Avatar
Mark,
You may want to clearly state on the FR/Z sweeps that they are the preproduction units, in case something changes. You don't want that data to be touted as representative if it turns out to not be.
It looks like an interesting driver. Good luck with finishing the transition to production.
John
Old 17th June 2009, 04:07 PM   #8
markaudio's Avatar
Hi John,
Thanks for your reminder. I did say "pre-production" and remind guys that there may be some variation. But, if there are variations, I anticipate such changes will be moderate. Most of you know I work hard to publish driver data that is very close to "actual" performance.
Mark.
Old 17th June 2009, 05:31 PM   #9
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Nice job on the new A7 Mark -looks like it's going to be a great little unit; possibly a little more flexible for different sorts of loads too. I like the reasonably low mass-corner.
Old 17th June 2009, 05:51 PM   #10
badman is offline badman  United States
badman's Avatar
Do these use an aluminum former?
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Alpair 7 - out of the bagHide this!Advertise here!
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 76 25th May 2018 03:43 PM
Alpair 12 - also out of the bag markaudio Full Range 23 23rd November 2009 03:48 AM
Alpair 10 and 5 Combination _henry_ Full Range 19 1st June 2009 08:24 PM
alpair 10 box width ? norman bates Full Range 9 15th May 2009 03:54 AM
Can anyone help TL or ML-TL for Alpair 10 _henry_ Full Range 3 31st December 2008 06:31 AM
