Looking for suitable small speakers
Old 13th June 2009, 08:42 PM   #1
Telemin is offline Telemin  United Kingdom
Default Looking for suitable small speakers
I am just starting out in the field of DIY audio and am hoping to build a 20W T-amp from the audiodigit kit audiocostruire kit. I am currently looking for some suitable speakers to go with it.
My only real stipulations are that they must be small, suitable to fit on a bookshelf or not much bigger, and must not be too expensive. Other than that I am happy to build myself and equally happy just to buy some suitable ones to start with.
Any suggestions are very welcome.
Thanks in advance
-Telemin-
Old 13th June 2009, 10:46 PM   #2
loninappleton is offline loninappleton  United States
Welcome to the group.
What's not too expensive? That means different things to different builders.
For bookshelf use, the Jordan 92s in Jim Griffin's (2.5l?) design
is worth a first look. I believe the Arum Cantus tweeter was added to this but best research it. 20w is plenty of juice to do a variety of things.
If in-room placement is possible rather than bookshelf that opens up more possibilities.
Old 13th June 2009, 10:47 PM   #3
nukaidee is offline nukaidee  Canada
since you are posting I assume you are looking for full rangers? Zaph has a design based on the B3S that is small and sounds decent.
http://zaphaudio.com/audio-speaker18.html
Old 13th June 2009, 10:48 PM   #4
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
When size is a constraint, the Jordans or the Alpairs are good
candidates, and there are some really inexpensive Alpairs.
Old 13th June 2009, 10:53 PM   #5
HareBrained is offline HareBrained  United States
HareBrained's Avatar
Check out the Mark Audio CHR70 thread. It an incredible value. It can be used in 4L sealed (up to 7L), or 5L-10L vented. I did an 8.1L dual chamber reflex that I'm loving. Overall, it very flexible. The published MA specs have been confirmed to be very accurate. It doesn't require any filters for your described location. And it's been reported to respond very well the EnABL tweaks. Lastly, in 4L sealed, it will reach xmax at 20W. The only down side is the sensitivity. It should only be used (by itself) in small- or medium-sized rooms. ~97db@20W.
Mark Audio also makes the Alpairs, mentioned by NP above.
Old 14th June 2009, 12:13 AM   #6
Thanks for the quick replies guys.
By not too expensive I mean that I would ideally like to keep the cost of the speakers below 100, but to be honest I have no idea how much hardware that actually buys in these circles.
I like the look of the B3S design, although they appear only to be rated at 15W - does this matter with a 20W amp? - and the CHR70s.
Backing up a little however, Harebrained talked about:
Can someone please point me to some suitable online resources and/or books that can help me understand what all that actually means. I have a decent grasp of the electronics of amplifiers and so on but the physics of sound and the rhyme and reason behind loudspeaker design is still quite mysterious to me. From what I have read so far I think I understand some of the more basic concepts but I haven't found many particularly useful sites for gaining an actual understanding of what everything means, what happens and why, mostly discussion of concepts it is assumed I already understand but don't.
I hope all that makes sense to you guys.
-Telemin-
Old 14th June 2009, 02:53 AM   #7
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by HareBrained
[B]Check out the Mark Audio CHR70 thread. It an incredible value. It can be used in 4L sealed (up to 7L), or 5L-10L vented.
What kind of BR alignment are you getting that works in 5L? My intention was to make these BR but it was just going to be too lumpy on the bottom.
Indeed these do respond well to EnABL ... they were knocking off some much more expensive stuff, but weren't quite up to the level as the full-zoot mFonken.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th June 2009, 03:22 AM   #8
no, you can use a 25W amp for speakers rated for 20W. just don't turn the volume up to max! but again, if you tried to run 10W at 100hz. chances are you'll still overpower those mini speakers. How loud do you want to listen to them exactly? usually home use for music (not home theater) 10-15W is plenty
Old 14th June 2009, 03:40 AM   #9
dave
No hijack of thread intended but Dave are these the first pics of the Enabled Alpair?
Many questions like how you paint with a pen on metal.
Old 14th June 2009, 03:49 AM   #10
frugal-phile(tm)
planet10's Avatar
Yes, Sorry for the grainy pic. Paint goes on fine with the pen. You just have to be careful.
dave
Looking for suitable small speakersHide this!Advertise here!
LOUD speakers to integrate into Leather jacket. Which drivers are suitable? grkn Multi-Way 3 20th October 2008 09:53 PM
best UK PC 2.1 speakers suitable for 3rd system jives11 Multi-Way 0 11th February 2007 11:11 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 02:19 PM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 06:06 AM
