#11 | |
John, out of curiosity: what amp are using, and are you driving them from the computer sound-card, or higher up the food chain? (i.e. outboard USB DAC, etc)?
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#12 |
The FF85k's are now broken in and sounding amazing! As noted above MJK came over to check out the F120a Metronomes, but took time out to have a listen to the Sprites. While the Sprites may look butt ugly and have no WAF, they sound GREAT!
That doesn't mean that I have abandoned the micro-Fonkens--those are under construction. On the other hand, my enthusiasm for the FF85k has me planning two, more extensive builds for next summer using this very special driver. So little time. So many speakers to build...
A day without music is like a day without food. |
#13 |
Hi Jim,
Glad the FF85k's are working out for you. If you were going to build a "regular" enclosure for these based on the calculations you made, what would be the particulars? For the 1.77 liter volume you mentioned earlier what would be the port size and resulting tuning freq / F3? |
#14 |
Hi ped,
I tossed out the calc. I did based on the Weems book, but a quick visit to Madisound for their link to an on-line calculator yielded the following: V(box)= 1.82 liters F(box)= 104 Hz Ripple= 0.02 dB F(3)= 96 Hz Port D= 1.06" Port L= 2.59" Port area= 0.83 sq. in. Not identical to what I figured out from Weems, but close enough. Cheers, Jim
#15 | |
uFonkens in Macassar Ebony, along with Kingrex T20U amp & power supply - and iMac.. ![]() http://homepage.mac.com/tlinespeaker...en-0v9-map.pdf
#16 |
"John, out of curiosity:
what amp are using, and are you driving them from the computer sound-card, or higher up the food chain? (i.e. outboard USB DAC, etc)?" Chris, Nothing fancy running them. I have a Philips micro system that is a 5 disk changer. So I listen to CDs mostly but it also has an AUX IN that is plugged to the computer to listen to MP3s. The computer has a standard sound card. One thing that amazes me is the sound stage on these, especially the channel seperation. It could be how close I am sitting, but I do like the way these sound. John |
#17 | |
I have some curly/burl maple that is awaiting my pair. Like I said great little speaker and yours in Macassar Ebony look beautiful.
John Quote:
#18 |
What type of demping material should i use in uFonkens and how?
I'm listening to them without any demping material, the sound has got some king of sreaming side. I have been listening ff85k for about a year in closed box and 18W8531 in vented box with XO around 1k hz, now i'm building uFonkens and SP95 SS and fostex are a bad match. The bass from uFonkens is just right. Thanks. Last edited by VDV; 20th August 2009 at 10:50 AM. |
#19 | |
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#20 |
Can i use padding polyester?
I need to kill standing waves? Sorry for the rotated picture, i cannot change my message yet.
| Fe107e or FF85k? | type | Full Range | 9 | 18th January 2009 06:58 PM |
| Mods for FF85k | badman | Full Range | 26 | 28th May 2008 07:25 PM |
| Ff85k? | Kensai | Full Range | 1 | 25th April 2007 12:22 PM |
| Looking for Foster FF85K | NickC | Swap Meet | 0 | 16th April 2007 05:28 PM |
| amp for Fostex FF85k | tame | Multi-Way | 0 | 28th February 2005 08:21 PM |
| Page generated in 0.12324 seconds (83.85% PHP - 16.15% MySQL) with 11 queries |
