Yet another Lowther cab quiz
Old 30th May 2009, 08:12 PM   #1
brownie is offline brownie  Canada
Default Yet another Lowther cab quiz
Hi
I'm looking for suggestions for probably a Lowther driver based project.
I recently finished a pair of Enabled FE 207/FH17 Half Changs for my second system. I've been quite impressed with what they do. Big thanks to Planet Ten Dave for his patience and willingness to give advice and Scott for the design work.
Now I'm curious to see what people would recommend for a replacement speaker for my main system. Lowthers appear to be the next step up the ladder in wide band speakers so this is where I'm leaning.
-I listen to rock, blues, electronica/trance and some girl & guitar stuff pretty much in that order.
-The room is fairly live, 12 x 24 feet with std 8 ft ceiling.
-Speaker placement is fairly open - the current speakers are 6 feet out from the back wall.
-Amplifiers are not a serious issue. I have big and small power tubes, big and small power SS and an old pair of NuForce amps to play with. If any of these don't match up really well I would not be afraid to explore new options but from what I have on hand, I would have a very good idea where to look.
Budget is no more than $2K US for the drivers,
With my music preferences, I really want the bass to go at least as deep as the Half Changs.
They need to sound good a spl's of about 70-80.
The logical choice seems to be a Lowther based unit but I can't find a cabinet that goes down very deep. The Medallion is quite complex and large yet is only good to 60 Hz from what I've read about it and needs to be corner loaded to get that.
The MLTL seems to be best choice for bass, but does it get the best out of the driver over the rest of the frequency range?
It is the hands down winner for construction ease.
Lowther's Alerion seems like the sort of thing I'm looking for- reported as being very quick and open with bass to 45ish. Is there an open domain/purchaseable design plan very close to it?
Other driver /cabinet options? No OB designs - they just don't work for me.
I'm asking about this now as it is cabinet building season here in the frozen waste lands.
Thanks for any input from you.
Kevin
Old 31st May 2009, 12:11 AM   #2
chrisb is offline chrisb
Any particular reason you think that Lowthers are "the logical choice" for an upgrade? Or why OB designs don't work for you?
If you have enough power that sensitivity isn't a primary criteria, and you'd like to try something from a different stable than the Fostex, I'm sure there are other makers to look at.
Don't get me wrong- of the half a dozen or so Lowther based systems I've heard at hi-fi shows, I've quite liked 2 of them (except for the price, of course). However unless you've actually heard a pair yourself, it'll be hard to understand why folks say that they're not for everybody.
In any case, there are a few options for enclosures for Lowther drivers that quite likely outperform, or are easier to build than the published "factory" designs. In fact, some of the most elegant solutions for Lowthers, both in terms of performance and build simplicity would be 2-way Open Baffles, which don't necessarily need to be huge panels, and if your Changs are 6 feet out from the back wall, the "footprint" of an OB shouldn't be much of a problem .
In fact, the second of the 2 Lowther systems whose sound I could probably live with were these OB's (Tone Tubby woofer IIRC) demo'd by Jon ver Halen at VSAC 2008:
don't ask about the amps, courtesy of crazy Jeffrey Jackson ( Experience Music )
kinda burnt out - taking a break
Old 31st May 2009, 12:26 AM   #3
TerryO is offline TerryO  United States
TerryO's Avatar
~~~~~~~~~~~~~~~Snip~~~~~~~~~~
Jon Ver Halen's Lowther/Tone Tubby design were my favorite speakers at VSAC, with the exception of the UnGodly, Enormous Goto driven Horns that Jeffery Jackson brought in his trailer from Tennessee.
Here's a report on VSAC:
http://www.enjoythemusic.com/vsac_2008/
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 31st May 2009, 01:49 AM   #4
Hi
OK I sort of knew the OB thing would rear it's head.
I reasons against OB up to this point - I could be re-educated.
1) most are IN MY OPINION simply ugly and as the system is in my living room........
2) Most are too big from what I've seen / read about. If I wanted a speaker the size of a wall divider I'd have bought Maggie 3.6's years ago.
3) These things seem to demand complex crossovers and multiple amps to really shine. -I'm trying to simplify my system -not make it more complex.
Why "logically'? I like the Fostex single driver sound and the Lowthers are reported to be simlar just faster and more detailed and fall into my price bracket for drivers.
I'm most certainly not married to any thing at this point simply casting about for ideas. My price point excludes all the "exotics' and most of those work best in OB as well.
The main speakers are SF Cremonas - the HC's are in the secondary system.
The ONLY reason I'm thinking of a change is the Cremmies need to be played a bit louder than I'm happy with to really show what you paid for. I'm a condo dweller so this is a real issue for me. When the treble & mid open up the bass is really starting to energize the room along with my neighbours blood pressure.
I'm considering 3 things right now: build new speakers for the main set up, buy a new tone arm for one of my tables or buy/ build a nicer 300B for the HC system. This is to see if I can find something that may satisfy me on the speaker front.
Thanks for the input
Kevin
Old 31st May 2009, 02:01 AM   #5
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
If not OB, I would look at a quaterwave, MLTL or whatever its called, or maybe a BVR
sometimes we know very little, and sometimes we know too much
Old 31st May 2009, 03:26 AM   #6
rjbond3rd is offline rjbond3rd
I really loved the Lowther DX3 in a Bob Brines LT2000 (which is an MLTL, which currently has FE207E's). But there's no way I would listen to rock on a Lowther in an MLTL. I tried listening to Steely Dan on them, and while the bass did indeed go down low, it didn't have the thump and bump required for rock / kick drum stuff - it excels in so many areas, just not rock in my mind.
What they did have was a freaky, eerie, palpable realism -- not the realism of the recording, but the realism of the actual instruments which would just jump out from the music and seem absolutely present. If you like that sort of thing, Lowthers may be for you. I have not heard the more upscale Lowther models, but the DX3 is not what I'd call smooth -- to me, it's some kind of euphonic, maybe resonant quality which I personally find pleasing (and which makes many other speakers sound dull by comparison to me), but some don't like it.
Personally, I would not spend the money until you can hear some.
The two Feastrex models that I've heard are smoother in my opinion, but not necessarily better, just different. Mr. Phil Townsend has graciously let me (and many others) hear his D5nf's (yummy!), D9nf's (sparkly!) and even his vastly more affordable FE126eN's (in Harveys and they ended up being my overall faves, because the whole package worked out to be a phenomenal match to the exact room). Still not a rock speaker though, in my limited experience.
The Alerion looks wonderful to me, I have not had the pleasure of hearing it. There are lots of BLH plans here: http://www.frugal-horn.com/spawn-plans.html Also, random unrelated thought but I wish I could hear these someday: http://www.gedlee.com/Summa.htm
Old 31st May 2009, 03:56 AM   #7
Hi everyone
These are precisely the kind of opinions I'm looking for.
In many respects combinations that don't work are more valuable to know about than some that are just up to the end user to decide.
My rock preference really does limit the choices.
I've already talked to Planet Ten Dave about this and his offerings seem to be the big double mouth cabinets which have many of the draw backs as far as size goes as the OB's.
When it comes down to it, my chances of finding something that has the elegance, size and performance of the Cremonas seems to be pretty low.
A friend of a friend just aquired a pair of Rethm Saadhanas so I'm trying to wangle an audition. If I like them I probably should just wait about 6 months - this guy rolls equipment over at an amaing rate and they'll likely be available soon enough.
Thanks for all the help & suggestions
Kevin
Old 31st May 2009, 04:33 AM   #8
Originally posted by brownie
... my chances of finding something that has the elegance, size and performance of the Cremonas seems to be pretty low.
Oh, what about the SEAS Exotic? I have not heard them, and they seem a tad pricey, but they are under $2k and go in 2 cubit foot sealed:
http://www.madisound.com/catalog/pro...oducts_id=8320
Old 31st May 2009, 05:10 AM   #9
rjbond3rd
Those Seas Exotics were on my list of ones I hoped people would comment on. I looked on as many sites as I know about and there just isn't much information available. Mr Pass said they worked well in an OB but not much more. The 2 cubic foot box made me perk up as that is in the ball park size wise and easy to build.
It seems they don't have the perceived value of some of the "proven" drivers but I can't find much more from anyone who actually bit the bullet and built the recommended sealed enclosure.
Maybe if I like the Rethms I might have to think about talking to Lowther America and see if they still have any of the Alerion boxes left. I'd have to do it in stages buy the enclosure then buy the drivers in a few months. It would never hurt to own a Terry Cain built speaker, man those are nice.
KB
Old 3rd June 2009, 01:46 AM   #10
serenechaos is offline serenechaos  United States
I understand where you're coming from about OBs brownie; of many I've heard, the only two I I could listen to any time @ all were the one chrisb posted the picture of, and Phil's Festrex system. --And I must add the Lowthers were greatly helped by the 304TL transmitter tube amp; I heard it earlier w/ a different amp and couldn't stay in the room, it hurt my ears so bad..
For rock--I know a pair of Austin 166s w/ bag end clone subs for rear deflectors will more than fill that size room w/ sound, or do quite nice for late night, low level listening, using a FE166ES-R. Or could ck w/ Jon for which Lowther he'd recommend/had close TS parameters?
But if I were going to buy a Lowther, I wouldn't put it in a cab...
Something more like an Azura horn; that would pick up efficiency, and would really be able to handle all styles of music.
Yet another Lowther cab quizHide this!Advertise here!
Interresting Quiz. Which tube is this? Radioman62 Tubes / Valves 5 28th December 2008 01:41 PM
Pop Quiz keantoken Solid State 3 15th June 2008 11:05 PM
a quiz about AC power vax9000 Tubes / Valves 75 28th July 2006 11:58 AM
Group Quiz JRKO Music 6 23rd January 2005 06:14 PM
math quiz- input z triode amp tenderland Tubes / Valves 7 23rd November 2004 07:05 PM
Copyright ©1999-2017 diyAudio
