Old 25th May 2009, 02:48 AM   #1
Default quality of high pass section of a plate amp
OK, I've built my H frames, solid maple tops & bottoms, maple plywood sides.
I've ordered the dayton audio plate amplifers (one 250 W for each channel.
I haven't ordered the crossover caps for my full ranger yet.
I was wondering what people think of the quality of the sound of the crossover thats in the plate amplifier (high pass section that is)
Thanks,
Paul
Old 25th May 2009, 03:11 AM   #2
planet10's Avatar
Most of them are somewhat lacking.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th May 2009, 04:18 AM   #3
ashok's Avatar
Considering that the typical plate amp is a mass market product one couldn't expect it to be populated with expensive/exotic parts.
However if the conditions are right you could probably upgrade some sections to 'improve' the sound of the high pass section.
I have seen some plate amps using SIL small signal chips and that will not be suitable for a 'high grade' DIP chip replacement.
The option might be to copy the high pass section and input stage and implement it with good DIP 'audio grade' chips and PP film caps ( if any ) and BG elco's and put it on a small pcb and mount it piggyback on the main board.
Not simple ,but doable I think.
AM
Old 25th May 2009, 05:03 AM   #4
Thanks, but it would be simpler, I think to just do a passive second order for the high pass, I just havent ordered them yet.
Paul
Old 25th May 2009, 06:45 AM   #5
planet10's Avatar
Paul
Most of the time to do 2nd order PLLXO requires a HF amp with sufficiently high input impedance.
A passive XO after the amps is a nightmare because of the rising impedance due to resonance (not to mention the cost)
What HF speakers are you wanting to XO and what amp do you plan on driving them with?
dave
Old 27th May 2009, 03:03 AM   #6
This is a amp/speaker build. I'm next going to build the tubelab simple se . Because it will probably mainly be used by my daughter (high spl's) I wanted a bigger full ranger, so I've ordered, but have not yet received the 10 inch audio nirvana.
The bass will be made by the H frame powered by the plate amp.
I've also considered a crossover like my vandersteen subwoofer (acoustat 2+2 with new york audio labs moscode).
with the vandersteen, the high pass to main speaker is crossed over with a input cap on the amp. This, of course only gives a 6 dB / octave high pass section.
But if I set it at 400 Hz (as in MJK's recommendation ((12 dB / octave)) with a 10 inch full range, I think it still might work, if not I can remove the input cap at that small value it won't be too expensive. Then I'd do a conventional speaker crossover.
Thanks,
Paul
Old 27th May 2009, 04:44 AM   #7
planet10's Avatar
The simpliest of PLLXOs.
dave
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 11:59 PM
quality but reasonably priced plate amp smallangryboy Subwoofers 3 9th June 2006 03:37 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 02:26 AM
Low wattage, high efficiency, high quality? Nordic Multi-Way 5 5th September 2005 12:12 AM
high jack the a/d section of panasonic sv-3800 gudderballs Digital Source 0 25th July 2004 01:25 AM
Page generated in 0.09930 seconds (76.38% PHP - 23.62% MySQL) with 10 queries
