Old 24th May 2009, 08:36 PM   #1
Default Merrill Driver: Which terminal is which?
Maybe a stupid question, but does polarity matter, so long as both drivers are wired the same?
One lug is thicker than the other, which gave me pause to wonder if one of them is supposed to be + and the other -.
Thanks in advance for an answer on this one.
Brenton
PS, Zigmahornets almost done!
Old 24th May 2009, 11:40 PM   #2
chrisb is offline chrisb  Canada
that's a couple of questions, and guess what - at least one of them will have an arguable answer - i.e. "does absolute polarity matter?"
no politics from me on that one
re the other - FWIW, with car audio drivers the larger terminal is generally the positive
but an easy way to test is to use a AA battery and test leads - when the cone moves out, whichever terminal is connected to the + of the battery is the positive
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 25th May 2009, 02:04 PM   #3
Thanks Chris,
I'll give this a try, being careful to avoid any political implications in so doing. ;-)
Old 25th May 2009, 06:37 PM   #4
This is a tried and true test. It works fine. But like it says, the biggie is usually positive. The battery test is fun to do.
Old 4th June 2009, 03:15 PM   #5
gychang is offline gychang  United States
Default Re: Merrill Driver: Which terminal is which?
I am on my 2nd Zig with Merrill's drivers, love the 1st set. Would appreciate pictures and your impression...
gychang
Old 5th June 2009, 01:51 AM   #6
badman is offline badman  United States
Custom Title
badman's Avatar
Default Re: Re: Merrill Driver: Which terminal is which?
gychang
I have a pair as well. Now that I made stable bases they're much better. Originally I'd undersized the bases and they were very tippy.
I'm in Tustin (and work in Irvine), if you ever feel like playing speakers, just PM me
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 5th June 2009, 11:31 AM   #7
Default Re: Re: Re: Merrill Driver: Which terminal is which?
nice to see S. Ca. folks like these Ziggies. They sound good in addition.
gychang
Old 5th June 2009, 02:08 PM   #8
Gy'
I'm so close to being done, but I sprained my finger pretty badly on Sunday, and so getting everything done now has slowed to a snail pace.
But, my update is that advice received here worked brilliantly!
I got th e cabs stripped of goopy emusion, sanded, and began building up coats of glossy varathane. I'm up to, I think only 2 coats. Maybe it's 3, and it's starting to look really nice. Another 3 or 4 to go, I figure.
Then, I'll screw on the bases, install the drivers, move 'em into the living room and start to break them in.
One other problem I encountered along the way is that my mitre/chop saw doesn't retain, as it should, a 90 degree angle on the horizontal axis, when the vertical cutting angle is varied. So when I did my 45 degree and 22.5 degree cuts, my pieces didn't line up right. There were gaps.
Anyway, that was resolved with the use of planing, sanding, and a mixture of wood glue and sawdust to fill the remaining crevices. Irritating.
Then again, might be the carpenter's fault. What was it dad always said? "Measure once, cut twice"? ;-)
Old 5th June 2009, 04:10 PM   #9
Gy'
or as my old man once noted "carpentry is a series of corrections for previous mistakes (yours and other's)"
and as Terry Olsen would add - it ain't DIY 'til the bondo highlights
Old 10th June 2009, 04:28 AM   #10
Default DONE!
Muwha-hah-hah-hah-harrrrrrr!
Pardon me, but, at long last, they're .... ahhh, .... done.
Promise pix for you tomorrow.
Made pretty exactly acc. to plans, with the mod that I added carpet felt around the magnets, and on the back of the magnet.
No break in. Straight to listening.
First impression, speakers against the wall, like my bookshelf speakers, and thought Joni Mitchell sounded a bit congested as she sang about California.
Moved them out 18 inches or so -- better. Sound fuller. Not sure how they sound relative to my Linn Index II's. They do sound good. Joni gave me goose bumps on A Case of You. As did Ricky Lee Jones on Last Chance Texaco.
A good start, I think.
Not sure what to expect a break in period to do for 'em. Thoughts?
Gotta say, as a first build, I'm pretty pleased!
More to come.
Night all,
Brenton
Merrill's zigmahornet driver still available? gychang Full Range 27 5th December 2009 04:40 AM
Pair of Merrill DCA4 drivers - Zigmahornet boudy Swap Meet 1 22nd October 2009 12:37 PM
WTB DCA4 Merrill 4" driver limono Swap Meet 1 12th January 2009 05:19 PM
3 terminal regulator with 3 terminal shunt reference BWRX Power Supplies 10 12th April 2008 03:49 PM
Page generated in 0.11287 seconds (79.66% PHP - 20.34% MySQL) with 11 queries
