Any comments on this new Tang-Band driver:
W4-1798S Would this be better than a curved cone shape? Tang band claims "wide dispersion performance". It's heavier than a comparable driver. I noticed B&W only used a flat cone on the midrange so maybe not a good choice for a ful range design. |
#2 |
My understanding is that most cones are cone shaped to maintain stiffness so they don't bend. Only in the past (couple?) decades or so have have certain new materials become common that are stiff enough to make a flat diaphragm out of without bending. Usually sandwich materials made from kevlar or carbon fiber with a honeycomb Nomex or similar type core, or in this case, Aluminum. There are several flat speakers on the market but they aren't as common as they could be and I'm not sure why. This one looks interesting.
Found more info in another forum: http://www.htguide.com/forum/showthread.php4?t=30060 |
#3 |
That impedance plot shows where the breakup is. Quite nasty too.
But damn thats a good-looking driver.
http://gainphile.blogspot.com |
#4 |
The W4-1757S is a little different. Lighter cone and Xmax of 2mm not 3mm. But probably representative of the design.
#5 |
aluminum sandwich cone is only 4" it might be a little breakup mode.
#6 |
The B&W Nautilus uses a flat diaphragm 4" lower mid unit, you now have the driver to do a clone with!
Very interesting driver, will be interested if anyone gets these. There are at least 2 different photos of them around, compare the datasheet to the parts express photo, and then the photo on the linked htguide thread seems to have a more blue looking diaphragm! EDIT: there are 2 different flat drivers by TB? It's the W4-1757S that has 2 different photos, and the original posted one appears to be a different/new model. |
#7 |
Tangbands requires a lot of work with crossover notches.
#8 |
Is that hexa-grid detachable? Looks interesting, but I still think there's a little way to go before flat diaphragm speakers will be really competitive.
"Flat cone" - it's actually more descriptive than "flat diaphragm", but then sounds silly when you think about it... |
#9 |
If you are curious about flat drivers in general, you might google FAL for some eye candy. Peter Daniel has discussed them over here, so check the forum too. They are a fine looking (and sounding, by all accounts) speaker, but not quite as affordable as the TB.
Paul Wild Burro Audio Labs - DIY Full Range Speakers |
| Flat compression drivers | holger honda | Multi-Way | 32 | 5th September 2006 10:20 AM |
| FS: Coral Flat 6B drivers | harryz | Swap Meet | 0 | 2nd August 2006 08:16 AM |
| FS: BNIB ED flat cone 10k and B315! | Audiophilenoob | Swap Meet | 0 | 26th July 2005 12:37 AM |
| Flat C drivers | Bidule | Planars & Exotics | 3 | 21st July 2005 12:07 AM |
| Drivers with flat diaphragms on waveguides? | 454Casull | Multi-Way | 7 | 18th January 2005 04:01 AM |
| Page generated in 0.09338 seconds (79.03% PHP - 20.97% MySQL) with 11 queries |
