Old 16th May 2009, 01:19 AM   #1
EUVL is offline EUVL  Europe
Default Alpair 6 Bass Reflex Bookshelf
This is only a preview.
My sister wanted a pair of new speakers. Have to be small, bookshelf, but enough SPL for small room (20 sq m). After some searching and consideration, I settled for a 6.5 litre bass reflex with the Alpair 6.
The pipe is 36mm ID and 103mm long (excluding the bellmouth). The form and construction is well known. No BSC, but a 4ohm 10W metal film in series, for now. Outside dimensions approximately 200mm x 276mm x 305mm. Walls lined with single layer of sonofil.
Here is the prototype unfinished (still need to sand and spray).
Absolutely gorgious thing (and not only the look). Thanks to MarkAudio for a great product. We are going to build 10 pairs of these.
We'll publish open-air measurement when we get a weekend without rain and with free time.
Patrick
Old 16th May 2009, 01:31 AM   #2
dhenryp is offline dhenryp  United States
Striking design!
Old 16th May 2009, 04:48 AM   #3
norman bates's Avatar
beautiful !!!!!!!!!!!!!!!!!
Old 16th May 2009, 07:32 AM   #4
It'll take us till July, or later, to be able to posted everything, including measurements and pictures of a full finished article (with custon design stands). In the meantime, pls bear with us.
Patrick
PS One thing we shall not publish is the drawing, to avoid us getting into trouble with a certain speaker manufacturer.
Old 16th May 2009, 08:20 AM   #5
A couple more pictures in the meantime.
PS :
The fringe patterns on the wood is of course not real, but an artifact of the JPEG compression as I have to reduce file size.
Old 16th May 2009, 08:22 AM   #6
Default Copy Milling Templates
2mm stainless steel, laser cut.
Old 16th May 2009, 08:25 AM   #7
Default Cut Out for Chassis
Old 16th May 2009, 09:09 PM   #8
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
very nice Patrick!
why the resistor?
Old 16th May 2009, 11:08 PM   #9
Geek's Avatar
Originally posted by Henkjan
very nice Patrick!
why the resistor?
They are 4 ohm drivers. Many tube amps would have a fit
Cheers!
Old 17th May 2009, 02:04 AM   #10
> why the resistor?
Very good question. To raise HF by some 4dB.
Partly determined from measurement (which was masked by too much room acoustics, hence the need to repeat outdoors). But we have also listened to different values from 2 to 5 ohms, and came back to 4 in the end.
Patrick
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 12:37 PM
css bass reflex paulfk Full Range 7 8th March 2009 12:25 PM
bass reflex for Ariel ME2 GAK Multi-Way 2 23rd December 2003 12:39 AM
Bass Reflex Guss Multi-Way 1 15th December 2003 03:33 AM
bass reflex? GAK Multi-Way 2 23rd October 2001 04:04 AM
Page generated in 0.09739 seconds (82.07% PHP - 17.93% MySQL) with 11 queries
