A thread for Tysen and variations on FAST - Page 9 - diyAudio
Old 24th September 2009, 06:03 AM   #81
chris661's Avatar
Ok, so - 20:1 TL for both the speakers together, probably ending at the top of the speaker somewhere, or at the back at the top... I'll sort that out later.
Did you stuff the TL, or just leave it as is? I'll do some testing of my own, but when I put it together, I'd like to know what my best result will probably be.
Thanks again,
Chris
My work: www.grimshawaudio.com
Old 24th September 2009, 06:35 AM   #82
frugal-phile(tm)
planet10's Avatar
Damping gets denser as you approach the terminus.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th September 2009, 07:06 AM   #83
chris661's Avatar
Ok, thanks for that - Dad's ordered two of the woofers, and the crossover stuff, so I'll be experimenting over the weekend. First job will be to bed in the woofers, then the listening begins...
Thanks again for all the help
Chris
Old 27th September 2009, 01:18 PM   #84
chris661's Avatar
Ok, so I made a test box with one woofer (works out around 17L), and 2 full rangers. Must be said - when I'm listening to that, the whole idea makes sense. Goes easily an octave lower than the speakers they are replacing, which is a good start, also, they look smaller - all you see is a thin line, compared to the Missions, which are relatively wide.
Integration isn't perfect yet, but it will be soon - messing with crossover points, but I think I'll go for around 300Hz.
Thanks for the idea, Dave
Chris
Old 29th September 2009, 06:36 AM   #85
chris661's Avatar
Discussing this with Dad (again, I know), and he pointed out that, using two woofers (one per side), would the speaker 'beam' at crossover frequency?
I have two of the woofers, so if buying the other two would bring this on, I'll keep the smaller boxes...
Chris
Old 29th September 2009, 07:10 AM   #86
frugal-phile(tm)
planet10's Avatar
I don't see why....
dave
Old 29th September 2009, 02:15 PM   #87
chris661's Avatar
I didn't at first, but I think it's to do with the fact that, when you sit to one side or another, the woofers would, effectively be out of phase with each other at certain frequencies. Methinks the 300hz wavelength is too long to notice minor deviations from sitting dead in front of the speaker.
The test speaker seemed Ok, but it used up the woofer's excursion pretty quick, but I suspect adding another 3 of them would bring this down a fair amount for the same SPL...
Chris
Old 29th September 2009, 03:49 PM   #88
frugal-phile(tm)
planet10's Avatar
At sufficiently high frequencies is can be an issue (more so when drivers aren't symmetrical wrt the listener's head, but that is much higher than where a FAST is XOed.
dave
Old 29th September 2009, 08:23 PM   #89
Pit Hinder's Avatar
Send a message via ICQ to Pit Hinder
YouŽd run into problems when using a single soupwoompher, but with the setup you plan you can stop overtaxing your dadŽs patience and purse.
Old 30th September 2009, 06:15 AM   #90
chris661's Avatar
It's been agreed that, after listening to the test cabinet, we should make one of the boxes, to get a good idea of what it will sound like - the test box was big and unbraced, so we figured that, instead of rebuilding that box, it would be better to make our own. Going to get the wood cut at the store (a lot quicker than with a handsaw), but this will probably happen next weekend, as things like open evening are happening at school, then there's a weekend trip so it will be next week before anything gets done...
Chris
300B Set amp some variations MartinV56 Tubes / Valves 0 12th February 2008 09:22 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
Zen Variations 5 Nelson Pass Pass Labs 66 5th August 2003 04:57 PM
Zen & Zen Variations-Part.2 billy Pass Labs 1 7th August 2002 06:24 PM
Zen Variations 3 - Questions vpharris Pass Labs 0 22nd May 2002 07:08 PM
Copyright ©1999-2017 diyAudio
